Guest Brian T
Anybody know if it would be a difficult task swapping this for a Pinto?
It "looks" like a blacktop Zetec engine at first glance, except for that lump hanging off the right hand side in front of the oil filter.
So, now I'm not sure about it.
Simon.
N3A
  • Capacity: 1998 cc
  • Bore: 86.0 mm
  • Stroke: 86.0 mm
  • Compression: 9.8:1
  • Valvegear: Chain driven twin OHC. 16 valves. Hydraulic tappets.
  • Fuelling: EEC-V controlled multi-point fuel injection
  • Power: 136 hp (101 kW) @ 6300 rpm
  • Torque: 175 N·m (129 lb·ft) @ 4200 rpm
Guest MarkB
Simon.
that would be the chain driven oil pump.
A timing CHAIN ? That's quite rare now I thought. So an "Old School" engine then. :)
I wonder what the reliability must be like for the rest of it.
Simon.
Guest MarkB
Most jap cars are timing chain but unfortunatly, like Vauxhall, their supplier must be poundland, they are suffering big time with chains stretching
