After a period of inactivity I am starting to look at problems I could not work out some months ago.
This problem is regarding the clutch cable and how to fit it to the clutch housing. My problem is that I can't work out how to get the cable through the mounting point on the engine and to the clutch arm which disengages the clutch and then to get the adjustment nuts either side of the engine hole that the thread passes through.
I could do it if I could get the cable out through the middle of the assembly but i have a crimped end on the other end where it fits to the clutch pedal movement.
I am hoping that some of you have the solution as I am stumped at the moment.
Regards
Chris
Guest busby
Hi I cut a slot in a niloc nut with my dremel to slide over the cable
hope this helps
Garry
Guest robinj66
Regards
Chris
The two adjustment nuts stay the same side (one is there to lock the other). If you want a nut on the clutch side of the cable then introduce a split nut as per Busby's post.
