Wiring Loom
Guest robbie
Guest robbie
Me again with more elect probs!
This time instrument panel connector does not correspond to Vicky Green wall chart wiring colours. Donor is 89 Sierra 2.0 GLS injection and I can't even find corresponding Haynes manual diagram! Again colours do not match up with order on panel connector. Connector is 12 pin and goes as follows:
from top as viewed (from back) when connected to instrument panel:
1 grey/green
2 brown
3 blue
4 brown/yellow (x2)
5 black/green
6 brown/black
7 brown/white
8 green (x2)
9 black/white
10 brown/green
11 black/yellow
12 blue/white
Hope someone has the answer!
Thnks Robbie
Guest TerryBarry
Robbie,
I worked the connections out as follows ('89 2.0 GL)
I also agree with your colour codes - so I haven't repeated them.
1 Panel Illumination from Rheostat
2 Earth
3 Alternator
4 Brake Warning from Master cylinder cap
5 Indicator switch
6 Fuel Sender
7 Temp Sender
8 Tacho
9 Indicator Switch
10 Oil Pressure Switch
11 + 12volts from ignition
12 Main beam
The Haynes manual seems completely wrong even if you do ignore those econo light connections.
I traced these from the socket on the back of the instrument cluster into the harness when I was thinning it down.
Terry
