Guest johanp
Hello,
I have a problem with my windshield wipers.
the engine is a modified Sierra.
Which brush ice towels you climb?
mini arm grooves are too big?
are there any adapters?
I searched the forum but I have not found.
good evening.
hahah this makes no sense 'Which brush ice towels you climb?' i think the translator didn't work very well for this part.
I think what you are saying is that the spindles (the part where the wiper arms connect) don't fit the mini wiper arms connections.
If you use sierra wiper arms and cut them shorter then you should be able to make them work. I cut the U shape part and welded it closer to make a shorter arm.
hope that helps
