My Kit Is Allergic To Kit Car Shows!
speedtripledan
Tested car last night all ok. Loaded up this am and set off early to beat the rain, got 1 junction down the m1 and the brake pedal is on the floor :( :( Unless 2 m/c are faulty it must be calipers.. there is no fluid loss just constant air getting in the system.
Guest peter2b2002
Never mind worst things happen at sea, still trying to get my 2b running + the heavens have just opened up here see you tommorow
peter2b
Dan this may be daft but have you any brake pipes running close to ex manifold? , I had some greif with the mazda clutch a week or too ago after fitting a 4/2/1 manifold no fluid loss but no clutch pressure ! rerouted the pipe cured it!! ok I'll shut the door behind me! mick :sorry: :crazy:
Good one Mower man.
Boiling fluid would be worth while investigating.
Guest peter2b2002
Just a thought have you double checked fluid level, 3 years ago i fitted a new clutch plate into my 2b took itout for a test run 1/2mile up the road NO brakes, what i had done when fitting the clutch i had jacked up the gear box to get the engine out and unknownly crushed the brake pipe in the tunnel only a small amount of brake fluid came out but enough to stop the bakes working the only thing i noticed was a drip of fluid under the car
Peter2b
