2B Bonnet Buldge? Where Can I Get One?
Guest windscreen man
Hi, i have a 2b with an xe in it, i have had to cut the bonnet to go over the engine, so i could shut the bonnet. Where can i het a bulege 17x19 inch. I cant find one on ebay to fit any other suggestions where i could look?? Plastic, grp, metal any will do as the csr is being painted thanx lew
the XE should have gone under your bonnet without needing to cut it, but seeing as you've already cut the bonnet you probably want to look at the Dax Rush bonnet bulge which should be big enough or you could do as these guys did here
I quite like the effect they got.
