Brake Bias
Guest zerorace
thanks for all the reply's will double check clearances on the clevis joints and go from there
Just to add to the mix my stylus is using two 0.75 cylinders, drums rear m16 calipers front. I had .625 front to start with but when trying to find the scotland problem i put the fronts on the .75, they felt to much nicer so left as .75 front .75 rear. Fronts lock 1st with bias bar in the middle.
