Camber adjustment.
steve1506
Hi Guys,
I am struggling to set up my front suspension on my 2B build  can some one please help and describe the process for making the  camber adjustment. Is it normal to split the top ball joint or remove the dummy strut from the hub bearing in mind that I have the improved wishbone setup so the cycle wing brackets get in the way when trying to adjust.
Manu Thanks
Steve D
I set the camber when fitting the wishbone upgrade kit, so the ball joints had never been pulled up fully tight until after I'd got the camber set. I could, therefore, just pull the stub out the top of the dummy strut (maybe just a tap under the top wishbone with a rubber mallet to free it, I can't remember).
