RedTrev
  1. RedTrev replied to Kerry's topic in Events
    and that'll just be me screaming for joy
  2. RedTrev replied to Kerry's topic in Events
    I'm in. Booked Friday to Sunday, pitch 30.
  3. https://www.vinreport.co.uk/ The website above gives a result for the reg plate as B371HJH
  4. No, I'd never met the guy before, he's local (Midlands based).
  5. Car now sold.
  6. Robin Hood 2B (wishbone front suspension). Oxford Blue. IVA'd by me in 2011 and registered as Robin Hood on the V5. MOT’d until May 2027. 16,800 miles, very reliable (only ever one breakdown which was in its early days due to an incorrectly positioned alternator bracket). Engine: Ford SOHC (Pinto) 2.0 litre. Sought-after 205 block. Shortened sump for ground clearance. Sump side-extended to maintain standard oil capacity. Performance cam; actual cam type/profile unknown. (See Dyno curves (photo below) from most recent rolling road session (2023)). Autosport Labs Megajolt fully programmable ignition controller, utilizing Throttle Position Sensor. Dual, on-the-fly switchable ignition configuration. Kawasaki Ninja ZX9R (2001 E1) Keihin carburettors on custom inlet manifold. (The carbs are bolted securely to the manifold using the original Kawasaki mounting rubbers (no silicone tube and jubilee clips)). Fuel pump perfectly matched to the carbs (from the same donor motorcycle). Robin Hood stainless steel 4 into 1 exhaust manifold and stainless silencer. Kenlowe thermo-electric fan controller. Transmission: Ford Type 9 gearbox (5 speed). Sierra 7” 3.92 diff with Lobro bolt-on driveshafts. Suspension: GBS front wishbone upgrade (significantly improving geometry and handling). Gaz coilovers all round, supplied by Dave at Dampertech. Brakes: Servo-assisted. Front - Sierra vented discs. Rear – Sierra solid discs. Wheels and Tyres: Fox 15", 5 spoke alloy wheels fitted with 195/50 15 Toyo Proxes R1R performance tyres (plenty of tread left). Interior & exterior: Fully carpeted interior. Mercedes SLK (R171) leather seats. Sabelt 4 point harnesses. Sierra instruments. Centre-hinged bonnet. Mike Satur rear windbreak screen (MGF/TF). Lockable boot cover. Vicky Green wiring harness (modified and upgraded with AMP Superseal connectors in vulnerable "wet" areas). Battery-top fusebox (ensures no unfused wires, including the large starter motor feed). Centre tunnel power socket. Wipac Crystal Clear 7" headlamps. Lucas 14W, 2 speed wiper motor. 3 speed heater blower. Supplied with a removable custom made Surrey top. £4950 ono ULEZ free (Transport for London) Clean Air Zone free (All zones) Please make contact via personal message.
  7. Yes Foz, you know me. First drive, resistance was futile 🙂 For sale, Robin Hood 2B, 2.0ltr Pinto £9250 or offers nowhere near that.
  8. I read this on the UK Cobra Club forum which implies ticket sales was the problem..
  9. Booked pitch 24, Friday to Sunday. Very few pitches left in the wider end of the site. 👍
  10. Hi Craig, count me in, most likely bring Ruby along with me, see you there 👍
  11. RedTrev replied to max's topic in Engine
    https://www.scribd.com/document/434558133/Classic-Ford-Ultimate-Guide-to-Bike-Carbs
  12. With a Spitfire and Hurricane (or 2 Hurricane?) flypast to boot
