Sierra 4x4
Guest bandituk
Hi folks,
Looks like I'll be going ahead with the build of a 2b soon.
Has anyone used the drivetrain from a 4x4 Sierra? If so,what are the pitfalls of a 4wd RH 2b,if any? Is there room for the 2.8V6 motor?
Any help/advice greatly appreciated.
Ian
People have fitted the 2.8 V6 & people have also looked at 4wd (incl Chairman Tim..) It seems that 4WD is pretty impossible due to the fact that there is nowhere to fit the transaxle & still give enough ground clearance (from memory, there may be other issues, do a search on here & you'll find the thread..)
Guest Tim Norman
saly is correct. Unless you want to do a lot of cutting and rewelding and then make the car left hand drive I would give it a miss. I wouldn't bother with the V6 either as it is very heavy altough some people have fitted it and are vey happy. it sounds bloody nice as well.
The majority of the running gear can be used but the front hubs need to be swapped for "normal" sierra ones.
I used a XR4x4 as a donor, give me a ring when you have got your kit and I'll let you know what I did to get round the small differences.
don't think I've had a sex change
You don't think!! you mean you don't know :p :p :p :p never mind Salty or is it Saly? :lol: :lol: :lol:
Guest Tim Norman
I've had a hard day! last day at old job so had to hand car back and find my way back to Notts from Lincoln.
Sorry SALTY :p
Tim
Guest battery joe
tim
you should of given us a ring and we would of taken you home :) :D :p
Says the lad too young to drive!! :lol:
Good work volunteering dad though :D
Tim - I would have made them pick it up... you want it, come fetch!! :lol:
Chris - I'm not about to prove it next time I see you!! :p :lol: :lol:
