I'm assuming it's a Sierra pedal box so the throttle pedal is separate and you should be able to remove the brake & clutch pedals as one lump. You can the remove the pedals from the box and reshape them. I modified mine by making V cuts in the side of the pedals, bending them to where I wanted them and then welding them back up. I would recommend you buy another pedal box to modify, just in case it goes horribly wrong ! Also, as Bob says, the welding needs to be good and the cuts may need bracing - you need to make sure the brake pedal is at least as strong as it was. The throttle pedal should be fairly easy to re-position.
Easier options may be :-
If you want the pedals higher is there room to move the whole pedal box up a bit ?
The pedals pivot on a round bar in the pedal box with springs and spacers to keep them in position. You may be able to move the brake pedal a bit closer to the clutch by swapping spacers (as long as it doesn't get too far out of line with the master cylinder) and that would save you chopping the pedals.
Hope this helps, Steve
