987 -
14
Everything posted by Thrashed
10.4.2020 - Good Friday So, today was all about the pedal box. I fixed the footwell end panel which was easy enough other than access. I had to use my hand riveter as the air riveter would not fit. Luckily it was only 8 rivets, which by hand was hard enough. Next was to figure out the throttle cable. The pedal box needed a small hole drilling to take the 90’ adjuster. This then fits to the pedal and is secured with a solderless nipple. I then found a nice route for the cable to the throttle bodies. The end of the cable has a welded on nipple which fits into the socket on the cam pulley. I used a couple of rubber lined P clips to secure it all in place. Next up was to get the pedal box back in. This was just a case of bolting up the 8 securing bolts. Next in was the master cylinders. As this had already been fitted in the mock up, this was easy enough to fit in. Fitting the balance bar was a bit of a struggle. As the bars that fit to the cylinders did not twist, it meant having to spin the whole cylinder. Got there in the end, but this was a bit of a faff and i am sure there must be an easier way to do this. After fitting up the throttle cable, I had to make a bit of an amendment to the coolant top hose. This was to get around the throttle cable bracket, as this sits at a specific angle so that the cable pulls straight. It just meant a slightly longer aluminium pipe. I beaded the ends and fitted this to the silicone. Not bad a bit of progress for half a days work and with this being the Easter bank holiday weekend, i should be able to get on with a bit more over the coming days
5.4.2020 So, the good news is that the aluminium sheets arrived. With the world in lockdown i bought twice as much as i needed, just in case! I need to make the end panel, which i had already made a CAD (Cardboard Added design) template for! This was easy enough with a bit of fettling and edge trim to fit closely around the steering shaft. Next was to work on the top cover. The shape is a weird one and has the added issue of the steering column cutting through the top edge of it. A few measurements and a bit more CAD and I had a rough shape. Finding a way to cover the steering column was not so easy. I ideally wanted something that was just big enough to cover the column, a wedge shape, with no fixings showing. Sounds easy enough. Plan 1, was to use some square plastic tube. This had the right finish as it is gloss black. Cutting to size and in a wedge shape was easy, trying to bend in a return lip for the hidden fixings, not so much. If you tried to cold bend it it would break, If you tried to heat and bend it the bend was not a tight 90’. After about half a day of messing about, including trying super glue, I gave up on the plastic idea. It was just not going to work! Plan 2, make it out of aluminium. This would mean having to wrap it, but as the panel was going to get wrapped, this was not such a big issue. The next issue was getting the aluminium into the right shape and with nice tight bends. To achieve this I have a sheet metal folder. The big issue was getting the folds in the correct order so that I can get all the bends in the folder. Net result meant having to increase the size slightly, but it worked. A bit of carbon vinyl wrap and a few rivets we have a panel. Still a bit of finishing to get some of the air bubbles out of the wrap, but i think it looks OK. … and the finished item. Still a few very small bubble, but you can only see then at the right angle in the right light, so as it will be under the bonnet most of the time, this will do. Next jobs will be to get the pedal box back in and connect up the hoses and see if they will hold fluid!
29.3.2020 So, COVID-19 has proper hit. Lockdown has started and deliveries are slowing down so this week whilst i wait for the aluminium sheet to arrive, i started on the calibration of the coolant temperature sensor (CLT) and the air intake temperature sensor (IAT). After the issues with the TPS, i wanted to make sure these are working. Net result, they are not!! The ecu is not reading that the sensors are plugged in or exist. Over the last week I have been working through the wiring to make sure this is all correct. I tested the wiring and this had continuity all the way back to the ecu. After finding the dodgy power wire in the ampseal plug i checked and one of the sensor grounds was slightly iffy too. Unpinned this and reinstalled and this made no difference that i could notice. Next step was to test the sensors. Hot air gun on the IAT and not a thing. Tried the hot air gun on the CLT and again, nothing?? Next step was to test the sensors themselves. CLT is easy enough to test. It just reads resistance, so off the car and into the kitchen. Sneakily put the CLT in the fridge, whilst SWMBO wasnt looking. Temperature probe on the multimeter said the air temp in the fridge was 6’ and room temperature is 18’ I pulled the CLT out of the fridge, measured the resistance. Waited 10 minutes for the sensor to reach room temperature and measured the resistance. Next was to get a hot reading, boiled the kettle and `plonked’ the CLT in a small jug up to the brass part of the sensor. Wait a minute or so and measure that resistance. This gave me the 3 readings that the ecu needed, but for a standard Ford sensor, this is majorly different to the standard Ford setting in the ECU. Good news is the sensor works and the readings are in line with what the Haynes manual says for a Duratec MX5 should be. Plugged the sensor back into the car and entered the new readings into the ecu. This made no difference?? I tried just randomly messing with the readings and found that when you get to a low enough resistance reading at zero degrees the temperature would swing from reading 81’ to -18’. Bit of google and help from a Facebook group and the general consensus is that it is an earthing issue. Double checked all of this again and there is definitely not an earthing issue. Thinking back over the issues with the ECU and the fact I still don't think I got back the original ECU after having it sent to be checked, as a last resort, I decided to do a full firmware reset. Take everything back to the factory settings and also upload the most recent version of the firmware. This was not overly difficult and only took about 15 minutes to figure out and action. Reconnected the ECU and started a new project. First and easiest test is the hot air gun on the AIT, Hay presto! The AIT is taking readings. Next was to put the CLT into a jug of hot water. Again, getting readings. Now the kicker is the readings are not accurate. What is strange is that the resistance readings i took for the CLT don't give the correct readings on the ECU. Also the AIT with the stock setting does not read below 21’. This is just a calibration issue, so should be easy enough to figure out. Just over the moon that I don't have to rip out the wiring loom!! Now to get on with the rest of the build!
22.3.2020 Managed to buy some 1mm wall aluminium tube. This was much better and the bead rolled in much easier and without cracking the tube. I cut the tube to length and beaded the ends. All replaced on the engine and hose clips in place. All this should be leak free but i still have a few bits to finish on the expansion bottle side, so not the end of this story yet. I then moved onto the master cylinders….. The original plan was to mount the fluid reservoirs up on the scuttle area, This was causing plumbing issues and space issues. Plus it just looked a bit rubbish. The hoses from the master cylinders were getting caught in the pedals and the reservoirs themselves were high up and causing clearance issues with the bonnet. Plan B was to mount the reservoirs directly to the cylinders for the brakes, but the clutch cylinder is very close to the chassis rail and will have to be remote, which for just the one reservoir is not an issue. This all fits nicely with enough space around the reservoirs and the caps fit on easily. The next job was to box this all in. I wanted to keep the fluids away from the pedals, but also my feet away from the reservoirs in case I have a pedal-panic moment. I don't want to go breaking the reservoir of the cylinder! The original plan would not now work as the reservoirs are now in the way. After a bit of head scratching I came up with a new plan. The original panel was on the outside of the chassis rails, but this meant the hoses needed bulkhead fittings. This means more chances of leaks, which i definitely don't want. The better plan was to panel from the inside of the chassis rails. Good old CAD to check for clearances. And everything looked OK. Up next was to make the panel. This meant removing the pedal box and the cylinders to gain access. It was then a case of cutting and folding the panel. Then it was a trim and refit until it fitted like a glove. Everything is looking good. I just need to find a way to secure the panel. I haven't decided if i am going to bond it in plan or make it removable for future access. I will then get the pedal box bolted back in and the cylinders back on. The top panel will take a bit more creative thought as it will need to clear the steering column. The original box is not so great and again didn't look good.
Thanks for the tip but actual fixed the problem by buying the correct grade of Ali tube. From the conversation with a local Ali supplier there are 2 grades. One for forming and bending the one that does not!
1.1.2020 Well, first day of the new year and not to bad a hang over from the night before means a bit of garage time. The next job is to build back up the calipers with the new pistons and seals. This was reasonably easy and the kit that i ordered came with everything needed, except new guide pins. The pins i have are in good condition for a bit of a clean and they were good to go. The next job was to fit is back to the car. The sierra hubs had a 10mm hoke for the original calipers but the mondeo bolts are 12mm. This meant drilling out the hub holes to 12mm. No going back now!! The carrier needed spacing from the hub too, so that the disc sat square. This was done with washers for now, but I will get some proper spacers made up along with proper length bolts for the final fitment. Everything fitted up and the clearance to the wheel is tight but it fits. Once i get the spacers and bolts i can go for the final fit. The passenger side caliper will need a bit of paint touch up as it has got a bit bashed around being fitted. I will then do the drivers side, but this should be a quick job now i know what i am doing! 15.3.2020 Been a while since i had a chance to work on the car. Had a half day spare so thought i would get the brakes finished off. I have made and cut the spacers. I made these out of some connector nuts, that i cut to size. I then drilled out the threads leaving a spacer 14.5mm long and a 12mm hole. This allowed the disc to sit right in the middle of the carrier as i had a total of about 3mm clearance. All fitted and looks good. I put an air line in the fluid feed to check the pistons were working. It locked up the brakes hard enough that i could not turn by hand and nothing is catching or rubbing that shouldnt. Wont know for sure until its on the road! Whilst i had a spare hour i tried to make a start on beading the coolant pipes. The aluminium pipe i had has a wall of about 2mm. This made beading very tough and as a result ended up cracking the aluminium and making a right mess. To fix this issue i needed a new plan. Rolling the bead into a 2mm tube was not easy, so the plan is to buy some 1mm wall tube and roll the bead in a more gentle fashion. Also the bead is much bigger than it needed to be, so will roll in a smaller bead. New tube has been ordered so hopefully plan B works out better.
17.11.2019 Managed to get the calipers and brackets sorted today. The first part was to get them clean! They were perfect on the inside, but the outside definitely had a good few years of rust and grime on them. I started with a liberale use of brake cleaner. This with a bit of the air compressor got all the dust and loose bits off. Up next was the wire wheel action. It was a bit of a pain but between a drill clamped on the vice with a big wire wheel, a dremel with little attachments to get in the tight corners and a paint removal pad on the angle grinder saw them clean up well. After the wire wheeling is was another brake cleaner bath and drying off with the air compressor. I fired up the garage heater as the paint instructions says it should be applied at 17-21’. The outside temp today was a lovely and warm 6’!! Left the heater running whilst having a cuppa tea and also left the paint pot and brakes in the heat stream so that it all warmed up nicely. This worked a treat and started the painting process. The paint applied well and the coverage is very good. I used the E-Tech brake caliper paint. The colour choices are very good and one of the colours was perfect for me. The first coat was drying nicely in the heat, so I hung these on metal rods. The instructions say to leave these 30 minutes before the second coat. By the time I got to the last caliper the 2 brackets had dried enough for a bit of a touch up in a few dry spots. I then hung them all back up and i will leave to dry for a day or two and then see if they need a full second coat. The initial look is very pleasing. They have come out much better than I thought and the prep work was worth the effort. This is what they look like currently. The pictures don’t do them justice as they are very bright and shiny. They will look awesome behind the black wheels. With these looking so good, it brings up the next big issue which is that the rear drums are orange, so going to have to do them now!! I am also thinking of a bit of livery on the calipers in white or orange. Need to think of something that would look good.
12.11.2019 Another spare hour tonight to play car. Bit more work on the brakes. Now i know they fit it is time to get them clean. First job was to strip them. They came apart easy enough. The carriers slider bolts are in good condition. These will be reused. One thing i noticed was the bolts are handed. They are slightly different as you can see below: The smooth looking one fits in either end, but the one with the splines only fits in one end as it is slightly thicker. The rubber boots for them are also in good condition, so will be able to reuse them. The pistons are in reasonable condition, but for £30 i can buy rebuild kits, that include new pistons and seals, so this will be the way to go. The next step will be getting them clean. I get the feeling this will be loads of degreaser and wire wheel action. I need to get them good enough to be able to paint and look good with the wheels on. I have decided on a colour, but that will be a big reveal at a later date!!
11.11.2019 So a bit of spare time tonight with the motivation from the weekend, I decided to get my 3kw heater unit up and running. Working in the garage over the weekend was bloody freezing. Not sure if its the weather or my age but I was feeling it! The unit needed a new plug, so swapped it over and it was good to go. 2 hours in the garage this evening with an outside temp of 4-5’ and after a bit I had to shut the heater off as i was getting too hot. That means the winter working can continue. Tonights task was to check the brake upgrade would fit. The plan is to fit a well trodden path of Mondeo Mk3 calipers, discs and pads. I know these will fit as others have used this with success. I removed the current standard sierra calipers and carriers and offered up the mondeo units. I will need to use some 6mm spacers but they fit. The sierra carriers fit through the hub with a 10mm hole. This will need opening out to 12mm as the mondeo carriers use 12mm fixing bolts. The mondeo units are so much bigger than the sierra units. So, now i have confirmed they fit the hubs, I will need to try them with the wheel on to make sure it clears. It should but will check before moving on. Once this is confirmed, I will start the stripping, cleaning and painting process. Trying to decide on what colour to paint the calipers. Shall i go standard silver? Part of me thinks go for a bright colour and i am thinking of going sky blue to match the blue on the body work. Not making any decisions until the calipers are stripped. They look a bit scabby at the moment and if they are too far gone, I might just end up swapping them out. I have also made some enquiries about having a heated front screen made. The company may still have the template from Dan (Brumster), when he had them quote for a screen. They are currently searching there records to see what they can find. Failing this they do have a standard Westfield screen pattern, which should be very close to what I need. Neil (Nelmo) has offered me an old screen frame that he has. It has a bit of damage and too many holes in it but will be something i can work with as i plan to have it powder coated, so can fill the holes and prep before hand. The side mounts i will probably end up buying from ebay as they all seem much the same and should do the job nicely. Once that is all sorted i will then have to sort the wipers. My current thought is to buy the kit from carbuilder solutions. It comes with everything that is needed and is brand new.
8.11.2019 Had a half day today and no exams to revise for this week, so chance to have a look at the car. Cable tied the loom plug to the ecu. Like magic it seemed to work. The TPS was talking to the ECU and calibrated. What i thought was going to be a few hours in the garage was 30 minutes and job done. Stu volunteers to pop over on Saturday and see if we can finally get the engine to run. 9.11.2019 Started the day with a cuppa tea, as got to be in the right frame of mind. Plus it is bloody cold in the garage, so waiting for the little heater i have to try and take a bit of the chill out the air. First job was to check the TPS still worked? Nope, something had changed and was no longer reading. Also the fuel pump was not priming. So, disconnected the fuel cut off switch from the loom and bingo the fuel pump works. The main power feed in the loom also seems to be a little bit loose. It doesnt pull out the plug but with a wiggle the fuel pump primes and everything works. Next was to check the TPS. Everything is still wired correctly and the TPS tested correctly. Only possible thing that Stu suggested was that as i have 2 sensor grounds there was some issue with the earth. Connected the TPS to the other sensor ground and the TPS springs into life. It calibrates and reads perfectly. So, the next and only item left was to start the engine. We cranked the engine and it built oil pressure and no oil leak which was great. The issue was it did not fire? After several tries, we noticed that the injectors were not `clicking’. We checked the spark plugs and we were getting spark. The fuel was reaching the fuel rail, but was just not getting into the engine. We ran a logger on the cranking and it showed that the ECU got the initial signal but then dropped out. We ran the crank logger and this was reading the tooth pattern. After several cups of tea and googling we came to the conclusion that everything was working as it should but the ECU was not seeing the crank signal at cranking. In a moment of clarity, Stu changed the ECU setting to read the crank from before to after and boom, the engine burst into life within a few turns of the starter motor. OMG, it sounds good. Admittedly it doesn't have a silencer on it, but it sounds awesome and with a rev it barks like a proper racer. Here is a video of the 2nd start as we didn't expect it to start the first time. Only ran it for a few moments as I have no coolant in it at all, but here is a short video: https://www.facebook.com/steve.mineham/posts/10221235756706963?comment_id=10221235786227701 Really happy that it now works. Just a bit of tidying on the TPS wiring and the rest of the build can continue. I will get a bit more spare time as we move towards Xmas. One of the first jobs will be to sort out the garage heater, its just far to cold! Thanks goes to Stu for his persistence in getting the issue resolved. I would have given up ages ago without him. Lets see how much more I can get sorted over the next few months.
Aug, Sept & Oct 2019 So the exams have been going well. Passed 2 so far with just 4 more to go. Over the last few months i have had a few hours here and there to have a look at the issues that stopped me and Stu getting the engine running. First off the list was the oil cooler. I assumed the gasket was in as it was not in the parts to fit pile. I pulled the oil cooler off. First thing i noticed was the bolts were only finger tight! This might be the issue, but i kept going to make sure the gasket was in. It was, so bolted it all back together and torqued the bolts. Next was to have a look at the fuel cut switch as to why it would stop the fuel feed. Checked for continuity and all appears the be working with nothing obviously wrong. I added spade terminals the the wiring so that it can be removed from the circuit if it continues to play up. Other jobs have been to calibrate the TPS. This turned out to be a much bigger job than i thought. After a few different days of trying to get it to work i had to go back to basics. I tested the TPS to ensure that the unit was working. This tested out all ok, next i tested the wiring. I continuity tested and resistance tested the wiring and again not issues, but it was still not working. The only logical conclusion was that the ECU was faulty, so sent this off to trigger wheels, who tested the ECU and this was all fine?? At this stage i was at a complete lose, each item in the system works but the ECU did not read the TPS. Stu popped over for another go at testing and trying to get the engine to run. Everything seemed to be in place and all my tests were good. Stu then noticed that the plug that connects to the ecu was not seated properly. On further investigation one of the locating tabs was broken off. No idea when or how this happened, but this was stopping the loom connecting. This ended the few hours of work with emails to trigger wheels to see what could be done. Long story short, it is nothing. The ECU is a sealed unit. There suggestion was to use cable ties to pull the loom plug tight into place.
6.7.2019 So today was the big day! With a level 4 diploma starting shortly today is make or break. If the engine starts it has a chance of being back on the road for spring 2020, if not then the car will mostly likely sit in the garage until Aug/ Sept 2020 before i can start work on it!! So, with no pressure! Stu (Duck) came over armed with his laptop and see if we could make Choo, Choo noises from the engine. We started with checking and calibrating the crank sensor. We then proceeded to trying to get the engine to fire. All of this took several hours as the engine would just not fire. The first issue was that the fuel pump was no priming? After several hours of messing about we removed the fuel cut off switch from the look and the fuel pump started working. We then found a few more issues, like about a litre of engine oil pouring all over the floor! At this stage it was early evening and we could not find the issue. After Stu left i had a look and it appears the oil leak is from the oil cooler. I then tried to remember if i fitted the gasket?? And did i torque up the bolts? Also the whole coolant system is leaking. I tried the system without swaging the ends of the ali tubes but every single one leaked! This means the car will be locked up now until Summer 2020 as the diploma will now take up all of my spare time! Gutted it didnt work but maybe fresh eyes in the future might reveal the issues.
4.7.2019 Had a few hours over the evenings, so thought I would focus on ticking off the speed sensor. Needed to make a bracket to mount the sensor close enough to the diff bolts but rigid enough as the sensor needs to be within 2mm! I tried to make the bracket out of some 3mm steel, but i couldn't bend it in the metal brake and smashing it in the vice did not give a good enough bend. Next up was some 2mm aluminium. This was thin enough to bend in the brake but strong enough to not flex. I then fixed the bracket to the tunnel floor panel that is welded to the chassis from the factory. I used M8 bolts and clamped it down tight. Didn't want any vibration causing the sensor to make contact with the diff bolts. The next step was to fit the sensor so it is 2mm from the bolt faces. Trying to find something that was 2mm thick to use as a spacer lead me to using a 2p. It was pretty close to 2mm think! The sensor just has 2, 13mm nuts, so adjusted to fit. The net result is a sensor that i about 2mm from the bolt heads and rocksteady. Just the cable to tidy up and that will be job done. Another item off the list.
23.6.2019 Not been much progress over the last few weeks due to work commitments. I did a to do list to get me to the finish, which looks like this: This weekend I managed to get a few items ticked off. The Spartan Wideband is in with just the sensor to be fitted into a bung in the exhaust. I installed the little LED into the dash that flashes to confirm the state of the wideband, so i can monitor too cold, too hot or normal. I then started on the fiddly wiring jobs. This was fitting the new steering wheel along with the 2 new buttons. The old steering wheel was very small 255mm d shape wheel. This was great until you are moving at speed as it made the steering a little twitchy and when parking, the steering is so heavy it needed changing! I swapped to the 285mm version, which still feels good in my hands, so hope this fixes the little issues. I also took the opportunity to add 2 new buttons. The right hand switch is a momentary switch for the launch control and the left hand switch is for the map switch. This will be potentially a `sports’ button, or might just be pops, bangs and flames button! I then moved onto switching out the speedo.The reason for the swap was the original was a cable driven type and the new set up will not allow this to work. The new unit also comes with lots of features that the old one didn’t. The features include a trip counter, 0-60 and max speed. Nothing i really need but nice to have. The wiring is easy enough, as most of the wiring was already in the car so was just a case of reterminating the connectors. I also added the speed sensor wiring too, which means all I need to do is fit a bracket and mount the sensor to read off the diff bolts. I started tidying up the under dash wiring, so a few cable ties and that should be finished. I made a start on the fluid reservoir level wiring. The first 2 went according to plan, but the 3rd is faulty and not working, grrr!! The overall plan will be to add connectors very close to the lids as they will need to be disconnected to unscrew them. I thought I had the connectors to make this work, but I was wrong! I have ordered new items, so will get this finished once the parts turn up. Next up was wiring in the fuel cut off switch, which was easy enough as it was only 2 wires that cut the fuel pump feed and the cam and crank sensors got wired in. Again no real dramas, just cut the shielded cable to length and fitted the terminals.
2.6.2019 Got a spare bit of time today, so decided to wrap the pedal box cover, bolt on the fluid reservoirs and mock up the expansion tank placement. Turned out ok and have ordered some M6 rivnuts so i can bolt it down, but keep it removable for future access. The chassis rail top will get some new trim. I also ordered some cable tie bases so I can secure the braided hoses out of the way of the pedals. Once this is done it will complete the braking system for now! I have a set of mondeo brake calipers to upgrade the fronts. I figure with the bit of extra power, the extra stopping power would not hurt. This upgrade is on the reserve list of upgrades, so may end up being next winters project!
19.5.2019 Not much progress this week due to work and other hobbies. Managed to get the battery tray and pedal cover wrapped. Turned out OK. A few air bubbles in the wrap, so will leave it a few days and then pop them with a pin. This week I will be remaking the bulkhead panel and wrapping this. 1st June 2019 Not been much progress in the last few as i had run out of a very important garage tool! My bucket of motivation. Luckily the club had a track day at curborough, which has given me a motivation top up. Mostly spent time making the bulkhead and remaking the pedal box cover. The bulkhead i just took a template from the old one and then trimmed to fit. Easy enough and fitted nicely. Managed to wrap it in the carbon vinyl. I was starting to think it would look a bit too much but it isn't too bad and if I get bored I can pull it off and go for a different colour. The issue then came when I tried the pedal box cover. It was all the wrong shape and size, so had to start again. Version 2 worked much better and the fluid reservoirs fit up nicely. I just need to wrap it to match and then fit using some rivnuts. I did some more work on the wiring but nothing to show. This was just wrapping the loom and running wires to the desired locations. Some of the wires will not be long enough, so will be extended and some need terminating. This will just be a case of slow and steady!
12.5.2019 Not much visible progress this week. I drilled out the old bulkhead as the original one had more holes than swiss cheese. I will be remaking the panel, with a lot less holes. It will have a small cut out for the steering shaft, but this will not be visible as there will be a cover panel for that. The bulkhead shelf panel was remade too along with the pedal/ steering shaft cover. These panels along with the new bulkhead panel will all get wrapped in carbon effect vinyl for a bit of bling when you open the bonnet. I then moved onto tidying up the wiring and routing. Not much to see, but still loads to sort! Once it's routed it will get wrapped in conduit.
6-05-2019 This week has been sorting more issues! First part that went to plan was the coolant hoses all arrived and fitted up with the expansion tank. The expansion tank is yet to be fully fitted to the bulkhead as that needs `sorting’ it's got more holes than swiss cheese. Other and a few hose clamps the plumbing is done, so I moved onto the fluid reservoirs for the brakes and clutch. They came with a bracket that fitted all 3 in a line, that would be perfect if fitted to the bulkhead. This was the first issue. When fitted it means that the hoses that run down to the cylinders would foul on the steering column. The only real option was to move the reservoirs but where? I started playing with ideas and decided that separating the brakes from the clutch was the best idea. I used the supplied bracket and cut on of the mounts off. These then just got riveted to the chassis rails just below the surface. The plan will be, when I make the new panel for the scuttle shelf, that i can fit the panel flush and cut holes for the reservoirs. I will make this panel removable so I can access the steering column, pipework and pedal box below. The rest of the panel will be permanently fixed. The next step was to fit the new propshaft. Dave Mac made and supplied the new item, which is a great bit of kit. When I measured the length i didn't take account of how I was going to fit the prop. The diff end is sierra, so is just 4 bolts but the nose slides into the MX5 gearbox. What i did not account for was that handbrake brackets are in the way. This meant I didn't have enough space to slide the prop back, insert the nose and drop down to bolt up to the diff. The only solution was to either drop the diff out, which means all the suspension and rear driveline out, or to pull the engine and box out about 3 inches. I went for option 2 of moving the engine and gearbox and it all went back together with the prop in place after about 3 hours! The next job was then to replace the reverse plunger that fixes to the passenger side of the gearbox. I removed it whilst fitting the gearbox as i didn't want to damage it banging it on chassis railed etc. After huffing and puffing for about an hour, I could not get it to fit! I decided to take out the passenger seat and remove the passenger side tunnel panel so allow better access as i could not see what was causing the issue. It turned out that the bulbous end sticks out enough to hit the vertical chassis rail. After a lot of head scratching I came to the conclusion that the chassis rail needs to move. As the rail was moved on the drivers side already, i just matched that on the passenger side. Rail moved and ready for painting All painted and the reverse plunger installed. Just need to replace the panel and we are good to go.
22-4-2019 Today was bolting on the engine ancillaries and sorting out the plumbing. These all bolted back on without issue, all the clearances and the belt run is all back in position. This took a few hours to do but was quite satisfying as it starts to make the car look more complete. One issue I found was when i went to bolt the throttle bodies on the gasket supplied was incorrect. I messaged Dan from DanST, at 7pm on a Sunday night expecting a message back Monday and within a few minutes he messaged back. He confirmed that the gasket i had was for a CVH. An hour later I had an email with confirmation the correct gasket had been ordered and was being posted out royal mail recorded. The service that Dan offers is amazing. All issues have been sorted immediately without question. This is how a company should be run. Dan said it was not worth sending back the CVH gasket, so this will be coming with me to Stoneleigh to find a new home. The New gaskets arrived a few days later ready to bolt up. I then moved onto the plumbing. After mocking it up all wrong, i started getting all the new pipework runs in. I managed to find a diagram of a duratec that is up and running and working. I managed to reuse some of my old fittings. I got the pipe run from the water manifold to the radiator top in 32mm. I reused the old fiesta top hose as it was just the right S shape to connect from the aluminium tube that runs underneath the throttle bodies. The bypass hose was the original hose as this fits nicely under the throttle bodies and close to the engine block. Then ran the 32mm hose from the thermostat housing to the radiator bottom. The hose ran down and then parallel to the steering rack. Again, I used the original fiesta hose as it fitted the shape I needed. I am using the original fiesta oil cooler, so ran the 16mm hose from the thermostat to the oil cooler. At this stage i didn't have the parts needed to finish off the plumbing. I ordered up some new bends to run from the oil cooler to the expansion tank. I ordered a new expansion tank, which has 3 outlets. 2x 8mm and 16mm. This will bolt to the bulkhead. One of the 8mm outlets will connect to the expansion tank. The other will run from the other 8mm outlet to the outlet on the top off the radiator. I have also bought a non pressurised radiator cap now i have the expansion tank. Once all the new parts arrive i can get the plumbing finished and test for leaks! I have all new spring clips so hoping this all holds tight. As a bit of bling i ordered the 8mm hoses in clear and will be running orange coolant fluid. Saw this on a car recently that was running pink fluid and i thought it looked cool. Worst case it looks rubbish and i change it all back to black!
18-4-2019 So the Bank holiday awaits, which means i will get 2-3 solid days run at getting the car rebuilt. As a bit of a head start i got one of the little fabrication jobs out the way. I made an adapter for the coil pack. This would allow the Audi coil pack to sit in place of the original Fiesta version. I chunk of aluminum and drill bit and a tap and we have an adapter plate! The plate will need `shaping’ once i confirm 100% how it will fit on the engine and scuttle area. The east i will do is take of the sharp corners. 19-4-2019 (Good Friday) Only managed a few hours on the car today. The main jobs were to get the engine and box back together and then to get them into the car, hopefully for the last time. The second job was to get the pedal box back in and make the short pipes what goes from the master cylinders to the bulkhead fittings on the footwell end panel. The pedal box was easy enough to bolt back in place and fitting up the master cylinders all slotted together easily. The pipe work went easy enough and the end result looked pretty good. This all went to plan but doing it on your own is never easy. Finally gave in got my lovely wife to help, which allowed the engine and box to just drop in. The engine looks lost in the engine bay! It will get a bit busier when the battery is back in and the plumbing goes in, but that's a job for Bank Holiday Monday.
14.4.2019 This weekend has been mainly painting! Is it wrong that i like the smell a little too much? Before the painting I welded in the engine cross brace. This was just as awkward as the other side as the top and side is ok, but the inside, vertical and underneath is a pain. Whilst waiting for the etch primer to dry on the chassis i made a start on the gearbox and starter motor. I washed down the gearbox with some degreaser and then wire wheeled the whole gearbox and starter motor. I then used some silver paint to brighten it up and it turned out OK. The pictures make it look better than in the flesh, but when it is stuck in transmission tunnel it will do. Whilst these were drying i moved onto the engine. Same process of degreasing and then wire wheeling. The dremel has earned its place this weekend, but the tiny little metal splinters that throw off the tools are not fun. They fling everywhere and stick in your clothes and skin! Remember your PPE kids! This all sounds very quick and easy, but the starter motor took about an hour to clean, prep and paint. The gearbox took about 2 hours to do and the engine too about 2 hours just to clean and prep. Painting then took about 2 hours as I did it with a brush. This was easier than spraying as masking would have taken much too long and intricate. Again, the finish is not perfect, but it will do as after a few road trips it will be dirty in no time. By this time the etch primer had dried, so I moved onto spraying the chassis modifications. My main concern was getting a colour match to the satin black powdercoat. The local paint shop who supplied the paint said it would be a very close match and they were not wrong. It was an exact match. I had already used some of the can on the battery tray that i made, to house the battery in the nose of the car. As a result i ran out of paint and have a few dry spots, that will need a second coat, but the results so far look good. Next up, will be to finish off the painting on the chassis and then I can start putting it all together for, hopefully, the final time. One thing I noticed was that i am going to have to make an adapter plate for the coil pack. The mounting holes for the new Audi coil pack has different to the Fiesta ones. A piece of aluminium plate should sort this. If i get a bit thick enough i can recess the original bolts and tap holes for the new coil pack mounting bolts. The big question at this stage is, will the car be finished and ready for Stoneleigh? I only have 3 weekends left. One is the Easter bank holiday, so should give me some time to work on the car. The following weekend i am away and will not get any time on the car and the following weekend is Stoneleigh! My confidence is not high on getting it complete, but we will have to wait and see.
7.4.2019 Good progress has been made this week. Firstly the alternator has been sorted. The original Fiesta St150 alternator is controlled via a PCM (Power Control Module). This makes it impossible to use the original alternator in standard format. With the help of my local alternator man we looked at 2 options. Replace the internals of the Fiesta alternator with a regulator that will work on a kit car or fit an external regulator to achieve the same. The second option is to fit a totally new alternator that fits the same bolt pattern, fits the space and keeps the belt run in line. After a couple of days work, both options are possible. The external regulator was the only option to keep the original alternator, so I opted for a new alternator. Got this home and bolted up and fired up the engine. Ignition light came on, went out when the engine started and showed a 14.4v output at the battery. Very happy boy. This meant that I am now onto the strip down, clean and final rebuild. Dropped the engine and box out again (hopefully, for the final time) and made a start on the final works. I started with the new panels. The footwell end panel was the most complicated as it needed to fit around the new pedal box, master cylinders and steering column. I had to do it in 2 parts but i think the end result turned out well. (Please ignore the white protective wrap) This will get riveted into place once the cleaning and painting has been completed. I then moved onto the tunnel panels. At the foot end I kept the panel on the outside of the chassis railed to give an extra 30mm of foot width. As this came towards the tunnel i then brought this inside the car. The plan will be to have the main panels removable. These will be held in with rivnuts and button head bolts. This will make accessing the tunnel for installing and removing the gearbox much easier and will also give me easy access to the propshaft bolts. The final bit of work was to remove the other engine cross brace tube. This will stop the thermostat housing and dip stick making contact with the cross bar. The new rail needs welding but i have just copied exactly how Westfield do their chassis.
Below is the video recording Stu did of the first start! Not the best quality as he was recording me through his webcam via a remote dial in IMG_4681.mov
28.3.2019 I had a quiet afternoon, so though I would see about a first start. Stuart was on the Google hangout (it's what the kids use), so was able to talk and see the car through the laptop camera, but also was able to see the laptop screen to talk me through the final setup. The last bits we needed to do was to configure the crank sensor, so unplugged the coil and injectors and hit the `GO’ button. It spun and the engine turned and the laptop read the crank pulley for the missing tooth it needed. What a relief, that the engine turned, that auxiliary belt worked and the laptop was then configured, minus the Throttle Position Sensor. We connected the sense and 5v wires together to show the throttle as wide open and then manually configures the ECU to have a bottom and top reading. The moment had come to see if it would start. Stuart had loaded a very rough map based on a pinto to get it started with everything in terms of timing and fueling on the safe side. I connected up the coil and injectors. Stu hit the record video button his end for my laptop camera and I hit the `GO’ button. It turned about 4 times and then a massive backfire! Big enough to blow the throttle bodies off the inlet manifold. They were just pushed on and not secured in any way, so was probably a bit more dramatic than it actually was. Pushed the throttle bodies back on, swapped the HT leads 180 degrees and when again. After about 3 turns it burst into life. Made me jump and made a hell of a racket with only the manifold attached and no silencer, but she is alive! I did a little garage dance to celebrate (imagine Chunk from the Goonies!). I only let it run for about 10-15 seconds as it has not coolant in the system, but it proves is works and the oil pressure light went out, so one very happy boy. The final step before final assembly is to figure out the alternator wiring. I have from the original Premier Loom the warning light and the 12v feed, but the alternator connector has 3 pins. According to the Brise website, this is for a sense wire. I wired it as per the Brise diagrams, but i am not getting anything from the alternator. The warning light is not coming on and I ran the engine again and it is not getting a charge. I tested the bulb to rule out the obvious stuff, but the bulb is working fine. I have put a post out to see if anyone knows how these should be wired as it is starting to feel like the home stretch is in sight.
4.3.2019 The last few weeks have been slow progress but managed to make some progress. All of the coolant hoses are fitted. The ends just need beading and a few brackets making but nothing major. The new brake lines are all in. Decided to go braided ptfe, for a bit of bling and ease of install. This was one line to the front and then split at a T-piece to each of the front calipers. The rear did the same and the clutch was just a single line too. The fuel system was easy too as the duratec is a dead-head system. The fuel pipe is out of the pump and into the VW fuel filter/ regulator. I fitted the regulator close to the tank as this kept the return pipe short. This now means I have everything in place except the ECU and wiring. The ECU is on order and the job for this weekend will be figuring this all out! 28.3.19 The last few weeks have been a lot of head scratching with the new wiring. I have to create a new set of circuits to make the new ECU & fuel pump work. This involved 2 new 4 way fuse boxes and 2 new relays. The fuses are for the new fuel pump, Coil pack, 2 sets of injector banks the ECU feed and the wideband feed. The relays were a main relay for the ECU and the fuel pump relay. I decided to have 2 4 way boxed so that i had a few spare ways if needed in the future. This was all reasonably easy and wired in without issue. The next step was to mount the ECU, which I did in the passenger side on the little shelf just in front of the relays. This reasonably accessible but still nicely tucked away in a dry space. I then set about figuring out what of the 35 wires were needed and which were not. This then through up a second issue that the information provided by Trigger Wheels did not match what was in my hands!! Luckily the wires are all labeled along their length as to what they are, but I decided to double check everything and ensure the wiring was sound in the plug. This was all correct and with a few amendments identified what was what. Jump ahead a few days and with Stuarts help (the Duck) he sent me a different microsquirt booklet and this was exactly the same as my ECU was wired. I decided to bundle the wires i would not be using and keep them tucked up out of the way. I felt this was safer just in case I ever need them in the future. A bit like I did with the original wiring, I wired in the wipers and heater, knowing I would never have any of them, but they are their just in case. I then set about wiring all the new bits together. A nice touch from Trigger Wheels was although I only ordered the short loom, they supplied the longer 8 feet look. This meant that every wire was long enough to reach its final destination. With that all wired to locations i left the wires just laying loose on the car and engine, just in case anything needed to be moved or changed. All the wires fed through the firewall with a bulkhead fitting what clamps around the wires are you tighten it up giving a seal to the outside. The day then came that I had run out of excuses but to power it up. Knowing nothing about ECU’s (or building cars in general!) Stuart (the Duck) popped over with his laptop to do the initial configurations. Only a few small issues cropped up initially, but we finally hit a big snag. The Throttle Positioning Sensor (TPS) was not reading correctly. It had a wandering signal and would not calibrate. We set this to one side and decided we were in a position to see if it would turn and start! Awesome, the starter motor sprung into life, but no engine movement?? This then took about 10 seconds for me to remember that I had forgotten to fit the clutch and flywheel, doh! We called it a night as it was already knocking on midnight on a school day and Stu had a good 45 minute drive home on top. This left me 2 tasks to sort before trying another start. 1, check why the Throttle Position Sensor (TPS) was being weird and fit the clutch and flywheel. I tackled the TPS first as this was going to be the easiest. I tested the output readings in ohms to see if the sensor looked like is would be right. As zero throttle i was getting 1.07 kohms, at ⅔ throttle i was getting 2.51 kohms and then at Wide Open Throttle is was getting 1.26 kohms. This is not correct according to the Kawasaki manual, it should be a linear reading from closed to WOT. I spoke to DanST who supplied the kit and he suggested this might be FUBAR, but to send it back, they would test it and replace if needed. In the meantime i got about separating the engine and gearbox so i could fit the clutch and flywheel. The `lazy’ plan was to leave the gearbox in the car, pull the engine back enough on the engine crane so i could fit the clutch and flywheel and then pop it all back together. This plan started to unravel as i tried to tighten up the flywheel bolts to 112nm. With the engine swinging in the air it was not possible to stop the flywheel from spinning as I used a torque wrench. The more I tried by more dangerous it started to feel. Plan B, I dropped the engine onto the floor and then removed the gearbox, realigned the clutch and torqued the bolts. I then popped the engine and box back together and called it a night. The following afternoon, before our monthly RHOCaR club meet (27.3.2019) i had a spare 2.5 hours so though, let's get the engine and box back in the car. Managed it in just over 1.5 hours and then reconnected all the ancillaries and wiring. This is not prepared and ready for the first start. This wasn't going to be today due to the club meet. I also received a call from DanST to say that the TPS is broken and he was sending out a replacement. This should be with me by 29.3.2019
