Ford Focus Rear Suspension Bush Remover
  • Please log in to reply
3 replies to this topic
#1 Grim
Grim
    What do you mean by 'wash'?
  • Moderator
  • 3,708 posts
  • Car type:Fully stainless / green 2b, standard 2l pinto, self dismantling
Posted 11 October 2018 - 05:14 PM
Has anyone got a ford focus rear suspension bush remover i could borrow/buy, as per the link below. Seems like a lot to spend on a single use tool, so thought I'd check here first.
https://rover.ebay.c...tm/253712686998
Andy
#2 florin metal works
florin metal works
    Hants & Dorset Area Secretary
  • Area Secretary
  • PipPipPipPipPip
  • 7,830 posts
  • Car type:2B+
Posted 11 October 2018 - 05:23 PM
I've got a whole host of mechanical/hydraulic presses Andy, but you are rather a long ways up country -- will be in Royal Leamington Spa week-end after next at Model Engineering Expo if any help.
#3 Grim
Grim
  • Moderator
  • 3,708 posts
Posted 11 October 2018 - 06:13 PM
I've got access to a press, but that would require removing the whole arm, hub, brakes etc, which is a much longer job.
A two leg puller could also be used if i had a bespoke plate, which is what this tool does, but would take time to make
Edited by Grim, 11 October 2018 - 06:13 PM.
#4 florin metal works
florin metal works
  • Area Secretary
  • PipPipPipPipPip
  • 7,830 posts
  • Car type:2B+
Posted 11 October 2018 - 09:18 PM
My hydraulic press is portable --- Sykes Pickavant 15000 series -- But may need to turn a tube to right diameter for the pushing side.
E-bay 123287146326  is a picture of the kit I have plus loads more arms & ram extensions.
The base plate is two parts so can be adjusted to suit hole size required, side arms can be up to 12" long.
Edited by florin metal works, 11 October 2018 - 09:25 PM.
