Dim Very Dim
Kevin,
try this, copied from the other site, worked for me
Brown - Earth - for sidelight
Grey and red - Side light - power for sidelight
Yellow - Dip beam - power for dip beam
White - Main beam - power for main beam
Blue Green - to dim dip relay (Item 34) connection 38. This is then gives an
earth through 87A when ignition on and dip or main beam are selected, (power
from fuses 1 & 2 or 3 & 4). Or 12 volts from fuse 17 when sidelights selected
and then finds its earth through the otherside dip beam ( 2 bulbs in series
hence dim dip).
Hope this helps.
Les
