Help Please
Guest chenzo
Got a problem as it is cross threaded on the bottom. Can you help???
Hi Shaun
As I said previously the part in your picture IS NOT the shock absorber it is called a dummy strut.
If it is the bottom stud of the dummy strut / chrome shaft that is cross threaded simply cut it off and have the shaft drilled and tapped and a high tensile stud fitted.
Job done.
HTHs
