Pinto Sump Mating Face
peter_m7uk
Just looking at my collection of sumps and I have a query... I've got an original
sump from the 2.0 pinto, plus an RS2000 ali sump, plus a shortened sump acquired
from e-bay. My concern is about the mating face on the shortened sump, which
I intended to bolt on shortly. It has raised areas on the face where the bolt holes
are, whereas the RS2000 sump is completely flat and the original sump is flat
with grooves between the bolt holes (the shortened sump also has these grooves).
Anyone else got a sump with bumps on the face at the bolt holes? The bumps
are all the same height, so it does seem deliberate, but I was expecting a flat
mating face. Just want to check that this is normal and I haven't bought something dodgy!
Cheers,
Pete :D
Hi Peter I think you will find the raised bits are where it has been overtightened over the years , you could put put something under the holes and gently tap the raised part back down level HTH .
Bernie :D
