Stainless Sheet Metal
Guest danny_samb
hi all, where is the best place to buy the stainless panels from and what size do you recomend thanks
Guest The Modfather
Personally I would look through the yellow pages and find your local sheet metal supplier. You'll get all sizes on Ebay but the postage will kill you.
Keep it local, and if you need small bits I have found that donating to their tea fund gives you a pretty endless supply of these smaller bits.
Darren
Questions -- Where are you -- What sizes do you require What thickness Can help with sheets up to 2440mm x 1220mm x 0.7mm thick plus smaller sheets up to 5mm thick.
