Radiator
Guest Darren2010
I've got the engine out of my old monocoque and the rad is looking a bit tired. Can any body recommend a replacement for an old cortina rad?
I believe a lot of people are going for the VW Polo rad...sure someone else can confirm.
If you want to use something similar for simplicity, the one that kitspares supply for the zero was nearly the same size as the one I took out. I am presuming of course that it was a cortina type, it certainly looked similar to the ones listed on ebay except for the top and bottom tanks. The outlet and inlet were in the right place so there was mimimal plumbing required. I had to change the bottom support as the depth was different but used the same mounting holes. They supply them in capped or capless depending on the type of system you are running. The basic measurements are on their website but if you need any more let me know
Guest Darren2010
Thanks for the advice guys. I'll have a look at them.
