Speedo Fix - Help
Guest Mark Cosh
Ok next job on the tlc program is the speedo. Its an caiguage (old style) when ignition is on it displys a mileage of 345 and the needle flicks briefly. the backing light is on but nothing happens to needle at movement. it appears i have two wires coming of what looks like a sender unit mounted near gearstick housing. only one is connected and both are black! do these need to connect to speedo if so where? is there a way to test the speedo before replacing sender?
