Lost Spark
Guest tiggertom
can anybody suggest a starting point for fault finding a megajolt/eids 4 zetec setup ,on thursday i was driving along at 60 mph and engine died no spluttering or misfire just as if ignition was turned off,so i towed it back and this morning i pulled a plug out and no spark. megajolt an eids both powered up and earthed,can a coil pack fail completely any suggestions welcome
Have you tested the resistance of the primary and secondary coils in the coil pack?
Primary should be very low - usually 1 ohm or less, secondary could be around 10 kilohms or there about.
If you can use the coil manually to generate a spark at the plug without the controller connected, then it is likely to be the driving transistor in the controller that has failed.
As you're in Doncaster, I can pop round and take a look sometime. (Not today or Sunday as I will be busy with an archery tournament)
Simon.
Edited by Simon B
Guest tiggertom
thanks for the offer i will contact you after weekend if i dont solve it
If VR sensor cable has failed it can just stop
EDIS will run limp home mode if Megajolt fails
Coil packs usually only fail one pair so check power feed to EDIS
VR sensor connections
Coil pack centre earth connection
From what I see, coil pack centre connection is +12 Volts, not earth.
In any case, I could not produce a spark from the HT side when energised on a bench off the car. I had a spare coil pack which he is trying out now which I suspect is the case.
Simon.
Guest tiggertom
thank you to Simon B for his help turned out to be a failed soldered joint on centre 12+ wire of 3 pin coil pack input plug :)
Edited by waterboy
Ah, that would explain why all plugs failed. Last I heard from you it was one of the sides.
Anyway, glad you found such a simple fix. :)
Simon.
