2.0 Efi Dohc Engine
Guest Jonnyround2003
I used a one filter. Not a kn rip off. Just search cone air filter. Should cost aroun £16. I then used old elbow to inlet, then the idle control valve which I cleaned up firstthen some flexi tube to take it where I wanted the filter. No problems at rolling road test.
If it's the donor lambda sensor my money is on that
never had a lambda or a cat fitted, if you are useing the ford injection system then any friendly MoT station will turn it down for you
