Fuel Tank Wiring
deano266
Hi I have a super spec and the fuel guage Isn't reading anything. There is no power to the tank for the fuel level float and was wondering if anyone has the wiring diagram for this section and any ideas where it comes from as it is a sea of wires behind the dash. Cheers
Not sure on a Super spec, but most gauges are
power to one side of gauge, other side of gauge is lead to tank sender then to earth.
Take the lead off the sender and pace it to earth and you should get a full fuel gauge reading.
On the standard Superspec with the Escort Instrument Panel there are 3 connections on the Black multiplug
Pin 1 (green) +12 V Ignition switched and goes to the B+ terminal on the Fuel Gauge
Pin 5 (black) Earth for various things including Fuel Gauge
Pin 6 (white) From the sender and goes to the S terminal on the Fuel Gauge
And on mine it works backwards :)
Hope that helps.
No such luck. All we have is the crude hand drawn sheet that showed what to plug where. Here is what I have discovered so far:
http://the-superspec-journey.blogspot.co.uk/2013/11/the-electrics-project-services.html
http://the-superspec-journey.blogspot.co.uk/2013/11/the-electrics-project-relays_22.html
http://the-superspec-journey.blogspot.co.uk/2013/11/the-electrics-project-fuses.html
If you can add anything to we would all be grateful :)
