deano266
2 Followers
    Superspec
    Dean
    Oldham
9,340 profile views
deano266's Achievements
Wheely good builder!
Wheely good builder! (4/6)
8
  1. i would suggest leaving it running on the drive for a little bit ensure that anything that is unburnt is either burnt or ejected. For my MOT (i have a superspec with Rover engine) to get it through emissions has to run hot so make sure its arrived just in time for the MOT with the engine already at temperature. IN other words let it get nice and toasty before it goes in
  2. Yeah my garage is just wide enough to fit the car in with a tight squeeze down the sides. Jacking up looks like the way to go
  3. If it is an out of shape tyre what's the nest course of action as they were only put on before storage which was around September
  4. Just beenbdriving the kit in this beautiful (cough cough) weather and a very large vibration was coming through the entire car. First thought was balancing but garage said was all OK but at speeds like that it won't be tyres. Upon inspection one of the propshaft bolts attaching the mt75 gearbox to the shaft is missing the nut and looks snapped. Probably happened at the garage when clutch was done and hadn't noticed or bothered to tell me. What are the bolts that are required and what torque setting should I use Thanks
  5. @alanricheythe car has come back and I can confirm the 'superspec rattle' is no more. The mechanic said it was the spigot bearing as when he placed it in when determing the fit he could see it moving (as there was no bearing) along with all the scoring on the shaft and the bushing. Once placed in with a bearing there was very little to no movement and span cleanly in the bearing. I would definitely recommend doing it but due to the way the engine and gearbox come out I would only do it when gearbox is coming off anyway
  6. Yeah I tried but they couldn't find it on the system And the rimmerbros one didn't go over the splines properly. Fortunately I went to a local clutch place and he had a Ford spline 215mm clutch so got that. In terms of the release bearing I asked the mechanic and he said it was clipped in as he had to unclip it out. He is going to modify the arm slightly to accommodate the mt75 release bearing from kitspares as we can get them easily
  7. Okay, the pressure plate is from a rover 420 however the clutch material is where I'm struggling now. The original was a borg and beck 53131 and struggling to find what that came out of. Searching for the exedy mzk 2100 I can't determine what that is from either
  8. this is what happened to the clutch
  9. the reason the metallic rattle happens is due to the play in the shaft that goes in to the bushing. The shaft has a bit of slop in the gearbox, so as it is rotating its hitting and making that noise (or thats at least what he thinks it is). When the bearing is in place we will most definitely find out. In terms of release bearing i have got a proper mt75 release bearing so should be clipped in properly now
  10. Well good and bad news. So bad news first. My clutch was smashed to pieces and looked like it had exploded. Good news is it can be fixed and the mechanic seems sure he can sort the rattle. He said with the mt75 needle roller it's too small for the gap in the brass bushing, however with some epoxy or metal putty he can place the needle roller in secure it with that in the bushing and this should stop the rattle. He did note its not advisable but its the best solution in a bad fitting hole. He did mention that if the resin fails then it will most likely rattle still and go to the back of the bushing causing no damage so its worth a punt
  11. well i spoke to someone at GBS today and good news gentlemen, they still have clutch parts for the rover t series non turbo, they also noted that they still have loads of parts left for superspecs but not just on the website
  12. @alanrichey can you not use the clutch plate from the URB10009 0215 or does it need to be the EXEDY MZK2100 for the release bearing
  13. If we was to get this done at a garage how much would we roughly be looking at?
  14. @alanricheyclutch cable is all in one piece but there is absolutely no movement from the top of the clutch pedal, however whilst I'm at it the cable will be changed so that it's not something I ever have to think about. I'll get on it and have a look. Hopefully a friendly garage will help me out in lifting it up and out to drop the gearbox out. I will update on how things go and if I can get rid of the rattle that would be amazing
  15. Hi all, took the superspec to be a wedding car and it decided that this was a good idea to get stuck in gear. I can change gear when sat still, however once the engine is running fat chance of that happening. The clutch pedal won't even press more than inch even if I put all my weight on it. Sooooo, the question is what is the clutch from and how much do we reckon its going to cost?
