Mini Wipers
Guest keyper
Guest keyper
Just about to install the mini wipers I got from a scrappy today but the plug attachment isn't there. Does anyone have any idea's as to where the cables connect to on the spade connectors ? :huh:
Any help here would be great. :D
The image attached to this reply shows the red, yellow and blue wires leaving the park switch and entering the motor. Using a multimeter on the park switch you should be able to decypher which terminal is where. Compare this with the article on the build tips on the main RHOCAR site and you should have what you need.
Ant
