Sva
Guest Petemate
Looking good, sure it will be fine. Are you going to leighton Buzzard? The chap there was quite hot on design weights, make sure you fill it up before the test as he specifically asked. Good luck!
good luck for tomorrow pete, hope you get the right result and not the half dozen minor faults i got pulled on - 4 of them now sorted just the pipe mountings left, not in the mood for lying under the car today.
enjoy the experience it's not as scary as it sounds
Steve
Guest STEVE OXON
no worries pete, with all the cribbing etc you have had . and a sons dax thru you should pass no problem
see you tonite then at gozzards
steve
p.s do you want me to pick you up?????????
