cb750
Everything posted by cb750
  1. Got this driveshaft which I don’t need as I sold the Robin Hood some time ago. It was bought as a reconditioned driveshaft from a local motor factor’s for a Sierra drive train. It’s 26 spline at the diff end and is 84 cm long. Must be collected from Aldridge, West Midlands. £25
  2. Having a clear out and found my spare pair of top suspension arms that I kept for my 3A. Does anyone want these before they go to the tip? They are FREE but must be collected from Aldridge, West Midlands. Sorry but I will not post.
  3. Sold car so no longer needed. Pinto engine parts including sump which I was going to cut and shorten to give more ground clearance. Sump has had some scrapes! Starter spins on a battery test. Twin crankshaft pulley (rubber insert has some cracks). Sprocket with tooth missing was made for a megajolt ignition system. Collection only from Aldridge, West Midlands £25
  4. NOW SOLD!
  5. Selling my spare Pinto injection head as it’s no longer needed (sold car). I’m looking for £90 o.n.o Collection only from Aldridge, West Midlands
  6. cb750
    Sierra 3.92 Diff
    SOLD!
  7. cb750
    Sierra 3.92 Diff
    PM sent
  8. cb750
    Sierra 3.92 Diff
    Price now reduced to £65
  9. cb750
    Type 9 Gearbox
    NOW SOLD!
  10. cb750
    Type 9 Gearbox
    Oops! Forgot the price! It's £350 ono . Post edited
  11. cb750
    Type 9 Gearbox
    This was first bought from Westfield by the original owner but was never used. I bought it off him as a spare but have never needed to fit it. Since I have now sold the car it's up for sale. NOTE that this doesn't have the speedo drive gear fitted as it was supplied for use with an electronic speedo using an external sensor. It could probably be retro fitted by the buyer if required. Collection only from Aldridge, West Midlands. Private sale-no warranty or returns. I'm looking for £350 ono ITEM NOW SOLD!
  12. For push-in shafts. Not LSD. Turns smooth, removed from a running kitcar only for a car upgrade to bolt-on shafts. Collection only from Aldridge, West Midlands. Private sale-no warranty or returns. £100 o.n.o
  13. cb750
    Parts for Sale
    Hi Alan, yes you can have them, the other person has changed his mind about buying them. I'll send you a pm later today. Rob
  14. cb750
    Parts for Sale
    Photo of the top suspension wishbones for the 3A
  15. cb750
    Parts for Sale
    Having a clear out now that I've sold the car collection only from Aldridge, West Midlands but will take to Stoneleigh on Saturday morning if anyone is interested. Pair of used top wishbones for a 3A. £25 the pair Pair of new track control arms Sierra Firstline 5525/5526. £20 the pair Pair of used stainless louvred vents fit 90x300 hole. £20 the pair Used rear lights "7 type" NOT Led. £10 the pair New Ford KA master cylinder - no cap. £15
  16. NOW SOLD
  17. These were kept as spares for my Robin Hood 3A but now I have sold the car they are no longer required. They are used items so have mounting holes in them and the wings have been cut to suit the car they originally came from. The nosecone is in good condition, the intake hole will need finishing off. Collection only from Aldridge, West Midlands. The wings are £20 for a pair (select colour, green or yellow) The nosecone is £20
  18. This is a used bonnet that came off my 3A (but may fit others?). There are a couple of small dings and light scratches on it. It has 2 cutouts for cooling vents which are supplied but not fitted. Collection only from Aldridge, West Midlands. £40
  19. CAR NOW SOLD (sad day but looking forward to next project whatever that may be.) Rob
  20. I have had a rethink and the price is now £4400. Rob
  21. Now sold!
  22. Thank you both for your kind words!
  23. Forgot to add that it comes with a lever arch binder full of receipts and it's own workshop manual that I have created.
  24. My Robin Hood 3A for sale. 10 months MOT. 1998 on a C plate. A well cared for example which I have owned for approximately 9 years. Taken off the road after purchase to carry out a rebuild which lasted 2 years! I have decided to sell her as I want to do a new project. No expense has been spared. The car has covered just over 2000 miles since the rebuild. The work carried out included: stainless monocoque reinforced and professionally welded at the known weak points New suspension including coilovers, top wishbone bearing upgrade and tie bar conversion. Rear camber wedges. Recon steering rack. Quick Release steering wheel. New braking system. Replacement rebuilt 2 litre Pinto engine fitted with skimmed head, FR32 cam, vernier pulley, Fireblade carbs on Bogg Brothers manifold, Megajolt ignition with new coil pack and leads, oil cooler, lowered sump and guard, cool air intake. Made 140 bhp on Steve Walfords rolling road. New Radtec alloy radiator, Spal fan, alloy header tank, 3-speed heater for the cooler months! Recon diff by Barra Motorsport Wider front and rear wings to take the 17" KEI wheels and Rainsport 3 205/40 tyres, professionally painted Mazda True Red Custom made wiring harness, fuse and relay box. Replacement battery 2020. Retrimmed adjustable seats by Land & Marine. Tinted laminated screen with new wiper system. GBS dash with Smiths instruments. Centre hinged bonnet. Roll bar modified and 4-point seat belts fitted. Most steel parts have been powder coated, all new nuts and bolts. The car is correctly registered as a Robin Hood and is in my name. I am looking for offers around £4400 to include wet weather gear (never been in the rain since I've had it). Located in Aldridge, West Midlands.
  25. Craig, if Foz doesn't have them I will contact you, Rob
