mike slater
Everything posted by mike slater
  1. iv been trying to find out how the car builder solutions fog light control unit is operated ,ie is the fog light then switched on by a momentary switch or an on/off switch .if controlled by a momentary switch is it one press for on and one press for off ? if this doesn't happen how do you switch fogs off without switching headlights off and back on again .?or if its controlled by an on/off switch and you turn your lights on then fogs on ,then turn lights off when you put lights back on the fog light switch will still be in the on position so surely the fogs will come back on .
  2. hi im new to all this im just looking for ideas for the dash panel on my s7 .it has had loads of holes cut in it over the years ,i still have the cortina clocks and they have been moved at some point to the centre of the dash panel ,which im not too keen on .i was thinking of fitting an ally panel over the top to hide all the nasty bits and moving the clocks back to were they were originally fitted .i have also got to get this though an iva test . mike
