Winter Projects Finished
niduncan
I bought a mushroom filter on ebay which was to tall to fit.
I retained the base plate of the pancake filter, used the external metal mesh cut down by 20mm, from the mushroom filter as the inner mesh. Drilled a small hole every 30 degrees around the base plate. Put the mushroom filter foam over the mesh and then used cable looming tape to tie it down.
Job done.
I am sure the software would handle it but I have just remembered that I have a blocked off a vacuum takeoff where the crankcase breather attatches to the manifold. I shall stick the Magajolt on that tonight and see what happens.
Guest Giggling_Buffoon
Might be worth checking whether you are measuring total or static pressures... (just to add to the confusion...)
If anyone is interested I have a nice set of 'Q' curves - basically airflow through a dynamic loss is a function as follows:
m(T^0.5)/P1(Cd.A) = Q = F(P1/P2).
So you put in you pressure ratio and get Q from the curve. Then by having the effective area, upstream pressure and temperature you get mass flow.
Dead simple.
