Rear Light Cluster
Guest docter fox
Guest docter fox
just the standard rh brake/indicator set, one of mines cracked and ideally I'd like to replace both sides if possible
answers on here or a postcode if prefered :)
James
Guest graham dockerill
^_^ Can't do the clicky thing, but if you want cheap cheap, then go to www.towsure.com for light clusters at £2.95 each + £5 carriage
Guest docter fox
do towsure do the same style lights as the standard ones? (I can't seem to find them on the site :ph34r: ) it's a bit expensive just to get rid of a cracked lens, if so I could just switch the lens's over, or did you change to a different style unit? ;)
Guest docter fox
I saw those but they look different (sizewise) so I wouldn't be able to use the original backing plates ;) does anybody sell just the lenses? :ph34r:
Guest AWhite
Yeah i think we have one. It is a plastic rectangular, brake and indicator (no fogs in it).
It's just the plastic bit you want isn't it?
I'll send you a pic as soon as i can get one.
If the postage is not much you can have it for free.
Andy
