Battery With No Over Flow Pipe
Guest a8dyc
If its not one thing its another.Been out in the car a couple of times so far,when i came back last time i noticed that there was a couple of small splash marks on the car which i thought had come from puddles when i went out with the bonnet off to test for cooling.HOWEVER when i go out there today the marks have stained the stainless and i noticed under the battery theres lots of green scum building up.The battery has no overflow pipe on it so i reckon its been coming out the hole running down the battery and laying underneath it splashing around on its way.What can i use to neutralize it.
Andy
Hi Andy , use sodium bicarbonate AKA baking soda solution , that should do it ,
Mike
Guest a8dyc
Mike
Really what powder mixed with water.
Andy
yes just mix with water and wash off the loose bits and scrape off the crusty bits , and that should sort it out ,
mike
I had a leaky battery, which was staining the chassis. I thought it would only be a matter of time before there was a run down the stainless side panel, ruining it.
£24 bought a brand new sealed battery. No worries.
Guest a8dyc
Thanks Mike it is done.How do you people know these things,the stuff my misses bakes with sorts out that nasty acid stuff!!!
Enforcer.You are dead right that will be the next thing to purchase.
The list grows.
Andy
Glad you got sorted , now coat the metal to stop it doing it happening again ,
well i used to work with very large telephone exchange batteries in another life ,
now i only use the gel type batteries , i wonder why !
cheers
Mike
Guest keith12
most the stuff the misses cooks kills all known things, DEAD!!!!!!!!!!!!!!!!
:D :D :D :D
Guest a8dyc
:D :D :D :D
I bet you wouldn't show her that post!! :D
Guest ballin
bicarb soda = alkaline
battery acid = erm, acid
Seems cheap?! Where from?
My local motorfactors in Telford ...... I've put plenty of business their way as well as being a loyal customer for years ... they 'look after me'!
I bet they do if you turn up and park the company car outside. Anything to get rid of you. You are frightening all there customers away. :yahoo:
