S7 Steering Rack Change For Quick Rack?
Guest Mikeg68
Can anyone tell me what quick rack steering rack I can use in an S7. Present one is ridiculous. 32 turns lock to lock or something.
Also if anyone knows of a full exhaust going for a pinto engine would appreciate a heads up.
cheers
mike
If it's got the sierra rack it can be uprated or a power rack can be used with a loop pipe [ no power ] , other racks May be more difficult with the exception of mk 1/2 escort HTH mower man
Picked up a quick rack kit from Rally Design, not easy getting the pinion cover nut off but got the kit for £60 for 2.7 turns.
Guest Mikeg68
Intersting snapperpaul. Can you give me more info as need one this week. Cheers.
It's a quick rack kit from Rally Design!!!!
You get the rack and pinion.
You have to strip the old rack right back
Take the track arms off
Take the pinion out, this may need a fabricated tool
Remove the rack from the casing
Then reassemble in reverse order
So far I am to the point of gabbing a tool to get the pinion out
Guest Mikeg68
Sounds like a right chew. Isnt there one i can just buy and slot in, albeit with slight modification? Anyway, off to have a look at car today.
  • 4 weeks later...
