Newbie Help
Guest deano
Guest deano
Cheers Jim
Well i wont scrap it got to give it a go first! Not to sure on what root to take space frame front end from bulk head brace it up mount engine off of it cut the horrible under bonnet floor out make room for sump then mount double wish bones or single bottom arm with compression strut!!!! or replace (fabricate) the mounts for whats on it now,
Does the in board idea work on robin hoods handle etc etc
Yes, the inboard shockers work fine, so long as they are "better" ones, ie. Spax or similar. But the springs need to be replaced with 130lb units, if keeping the same pivot measurements, and they are much better with tiebars rather than the roll bar.
Let me know if you want full measurements & photo's of the front end of my car.
jim
