Guest Dickie
I was trial fitting the RH side panel this evening & it seems a very good fit with just a bit of trimming required along the chassis rail next to the engine mount. The concern I have, is the position of the hole for the steering rack, the rack boot rubs on the panel, is the hole position wrong in the panel? or does the rack need to be moved rearward? I don't have any photos of this portion of a finished car, I should have taken a few when I collected my car last week, but got a bit carried away loading my hire van.
you are doing very well if you only collected it last week, sides are one of the last things to go on
rack can be adjusted on slots to fit panel holes
if you are in Nottingham I would strongly suggest a return visit to the factory
I'm near Notts also if you want a look at a finished car.
Loads of pics in my album mate. (Link below).
Guest Dickie
Spoke to the factory today, looks like I just need to move the rack a little, I was going to leave the side panels off until later, but as storage ( and three children) is a problem, I have decided to fit them now. I've fitted the diff, fr and rr suspension, steering, pedals & most of the interior panels (lh tunnel panels not fixed yet) I may have a go at the scuttle panel at the weekend
I must have done it all backwards then !
I opted for the bonded on panels from the start. Ok, it made it more difficult to fit some parts, but not impossible. :)
Simon.
Guest Tim Norman
Won't repositioning the rack to fit the hole compromise steering and introduce bump steer?
I think you would have to move the rack a LOT to produce bump steer. I'm thinking he only wants to move it within the tolerances that are already on the plate at the front of the car. If you moved it over more than an inch up or down, then, yes, possibly.
Backwards and forwards at the same height will not affect bump steer.
Simon.
If its only fractional make the blo--- hole bigger !!! mower man
but perhaps ackerman? :p
Ha, I don't think even tintops have correct Ackerman steering either. If they did you wouldn't get the tyre squeal on max lock going round car parks like my old mondeo used to ! :)
Simon.
Guest Dickie
Sorted, I have moved the rack further up the mounting slot & it is now central in the side panel hole.
Simon.
Very true, i believe it's a trade off between low and high speed handling, with anti-ackerman being advantageous at high speeds.
There you go it should , all fit patience and a sit back with a brew can work wonders mower man
Guest Hammy360
Ditto that!
