Exmo Front Shocks
Guest m3wood
Guest m3wood
Hi guys
Basically what shock do I need to buy I understand it's a p100 insert but from what model and where can I get them from ? I'm a bit lost to be honest
Regards
Matt
Can't help on the model, I only found one listed. You can get the whole strut with spring cup from Eurocarparts but you well need to cut it up to get the insert out and there is no guarantee it would be the same size as the original.
I got a second hand unit from GBSC a few years back but I think it was luck as they had it in a box laying around. I was told by GAZ that they could make one to the dimensions for about £80 a shock
If you do get an insert you well need to press off the threaded collar and press it back onto the new one.
Hope that helps.
