Accuspark Stealth Blacbox
Thrashed
I made a plenum from a length of 22mm copper pipe about same length as manifold one end blanked and a brass Male BSP Thread Hose Tail Fitting soldered into the blank on the other end, then drilled 4 holes into side of pipe and fitted 4 more hose tails which connect via silicon tubes to 4 hose tails set into the bottom of the manifold legs, works tickety boo hose tails bought on flea bay pipe found on garage floor blank ends from B & Q
its self supporting eg it hangs on 4 short lengths of silicon hose because i was too idle to do anything to bracket it ,its been to Germany and round the Nurbergring and back to Dundee 2000 miles so far and still ok
hope this helps
Derek :db:
