Top Notch Customer Service
tractor
Guest peter2b2002
I had the same thing on my speedo I used the same type of hall effect sensor I think, on mine it fitted to the end of the speedo cable,just to cut to the end, my speedo cable broke inside the gear box so I went for another hall sensor that used magnets ,I could not get the speedo to work 3years later I found I had left a +12v on more than 1speedo wire, I diconected it bingo speedo worked ,check that you don't have more that 12v feed to speedo as I blocks the other signal feeds
peter2b
