Smiths Gauges
Guest Jonnyround2003
  • 1 month later...
The smith gauges should come with a wiring diagram or at least a link to the car http://www.caigauge.com/ Caerbont Auto should still have all the wiring diagrams thats where i got my details from. +ve feed is from the voltage regulator/stabiliser the other point on the gauge is for daisy chaining one gauge to the other continuing the regulated voltage supply along the chain. They are all earthed via the lightbulb connector which makes a huge surface area for earth. Thats the wiring done, then make sure you have the right senders for the relevant gauges (temp and oil maybe fuel).
I'm reiterating some info already said which is spot on just covering some bits i needed to know.
