Front Brake Upgrade
DoctorDee
8 hours ago, DoctorDee said:
There is always a way.... So I have a KA master cylinder which I will have to use with a remote reservoir  in order that the bonnet will close......What did you use for your master cylinder push rod please  Dan
I honestly can't remember where it came from, it's probably off Demon Tweeks or some other similar online place, coupled with a suitable clevis for the pedal. It's nothing special, I just cut it down to length, there will be some pics in my build thread somewhere... and I made a pedal stop to ensure you can't pull the pedal up too far and the pushrod could fall out or partially remove and lose alignment, which would be pretty disastrous :(
Test Footer
