West Midlands Monthly Meet 30th April 2025
West Mids post-Christmas meal Wed 29th January 2025
I'll be there and someone wants an ice cream ;)
Track day
Weather won't stop me if it's horrendous I might bring "the other car" instead... Also, fwiw, if we're short of numbers I could spread the word to another motor club who might fill 2 or 3 more spaces if need be...
Track day
I'd be interested, depending on dates/etc... although at the moment the car is off the road, but should be back up and running soon...
Wheeled garage cabinet (PC/etc)
Re-adding photo as it got lost.... anyone interested in this otherwise it's going down the tip, which seems an utter waste as it's really quite useful for anyone after a bit of rolling storage in the garage...
Plasma Cutter - Clarke Plasma King 25
As per pics, plasma cutter. Cuts up to 6mm steel. Very little use over the years, has done less than 10 hours of work - an extravagant purchase many moons ago but I don't use it, so it might as well go. No goggles but then the goggles that came with it were never great anyway... VERY heavy, so collection only or can arrange to meet somewhere convenient depending on distance/etc. Item located near Kenilworth. £175 ovno
Robin Hood ExMo Front Damper
Is my memory failing me or weren't they Ford P100 (Cortina-based) damper inserts into a modified upright or something?
New web page dedicated to the Exmo
As an ex-batch 2 buyer, gets my thumbs up too! Not a criticism, but there's plenty to add/flesh out, and I'm happy to contribute if necessary...
West Mids post-Christmas meal Wed 31st January 2024
Stick me down for 3!
Radiator Suggestions,
I did this in an Exmo but in order to get it into the nosecone it had to be angled/tilted back and this affects airflow through it; I'm not saying it doesn't work, but just try and keep it to a minimum (the angle I mean). I used a 90's VW Polo diesel radiator from memory - they are quite compact. My memory is hazey but it might have also been fitted to some other models like a Seat Cordoba or somesuch....!
The Club Gazebos
Cool, ta. Leave it with me. We have a committee meeting tomorrow night so I'll mention it then. Any sides to them? What are they made of, steel (the frames I mean)?
Jenvey TB trumpets / Tank Foam cubes
4x Jenvey 45mm throttle body trumpets, 40mm length, with bolts. Some slight cuts as can be seen from the pictures. £50 12x 80mm fuel tank foam blocks, as sold by Merlin Motorsport. For use in tanks to stop fuel surge (make sure they don't interrupt with your fuel gauge sender though! Not suitable for pendulum-style senders in unbaffled tanks). Cover the postage and buy me a beer or two (so say £10 posted?)
The Club Gazebos
Hi Kerry - any pics/detail of sizes? Another motor club I'm in might be interested so I'll pass the details on. Everything ok on them - no rips/tears/bends/etc?
Drive Shafts - Will These Fit?
Inside the CV you have your tripode joint and normally there's a spring and a little cup in there that just push the joint back out - the danger is that (while driving) you compress the joint to the point you use up all the travel and smash the tripode into the end of the CV cup; this would end up damaging something (probably wrecking the tripode bearings or even smashing/splitting the CV cup I guess, in extreme circumstances). They should compress by hand relatively easily but build up resistance due to the spring - there will be a natural point where you can't compress them any more. "More force" sounds like you're just pushing against the spring - you won't damage anything here, that's fine. You'll get to a point where you've used up that spring travel and your tripode is hitting the end of the CV channels they run in - you don't want to be hitting this when the driveshaft is level (ie. when the wheel is level and the shaft is at it's shortest point). You want a bit of leeway... likewise at full bump/droop, you don't want the tripode pulling all the way out of the CV!
- Clarke 150TE Turbo welder
