Hi, loving being the owner of a 2b, not that I’ve had a real chance to use it yet though….
y brake master cylinder has failed, so I have front brakes, but no rears, and I’m struggling to find the right replacement
the cylinder has 74660862 and Q138 (I think) on the lhs
and
ABCDEGHJKLMN (then a circular logo (that I can’t make out)) .3. On the rhs.
I ordered the one that I thought it was, but when it arrived the mounting holes were approx 75mm apart, where as the one on the car has centres at around 95mm
Anyone got any ideas. I’m I being terminally daft (I can’t find a listing that has the mounting hole spacing on it)
thanks in advance for your help (it’s the last thing to do for this summer, it even passed the MOT as is)
cheersben
kit was designed for a ford sierra doner.
Master cylinder would have come from the doner, I think that all sierras had the same master cylinder.
Hi Ian, thanks, but I think there are a few similitudes from what I can tell.
based around bore size 20 v 22.2, seal type and flange size, which is where I’m stuck.
I have seen some people have junked the servo nd gone with a narrower bore master cylinder, but I’d rather not have to replace brake lines at this point, although maybe something I’ll do in the future 😁
I presume that your kit is sierra based.
I believe that there were a few MX5 kits but I know little about them.
A couple of pictures might help.
yes, it’s sierra based, from a 2.0efi (estate as best I can make out)
I will try to upload some, but I’ve been struggling to get them under 100kb. Will have a go tomorrow.
thanks
ben
Edited by BenGray
Missed some info off
