Everything posted by IanS
Staffys Xmas get together
Christine and I will come
Springs for RH EXMO front suspension?
Yes they are custom made.
there was a post on this years ago https://www.rhocar.org/index.php?/forums/topic/27038-exmo-suspension/page/4/#comment-412997
- Safe total pre-timing setup for 2.0 105HP Pinto Engine with vacuum hose attached
- Fitting windscreen/wiper/washers to my 2b
Don`t shoot the messenger
Had an excellent day out until Martins hollow legs betrayed him and I had to find half a cow to feed him. Thanks for organizing.
LED brake lights
Be warned that the standard wipec rear light cluster points the bulbs sideways. Replacement LED bulbs then shine sideways, not back☹️
Help - fibreglass repairs
Sorry to hear this. I hope that nobody was hurt. Is it just cracked or more more serious? Car still derivable? Fingers crossed for you
National Kit Car Show - Malvern 30th-31st May 2026
I do not know what ignition switch you have. I had this problem on my sierra derived switch. The contacts inside the switch had corroded. I stripped the switch and polished the contacts reassembled it. The problem went away.
- Accelerator Cable plus another query
Like Foz I have a pass out and should have similar timetable. Ian
Snapped Timing Belt
The pinto as standard is a non contact engine but with a FR33 cam I do not know. The sound of valves hitting pistons is like a bunch of twigs snapping. As for damage you could just try fitting the new belt and seeing if it starts. if it does I would replace with a new one anyway. Otherwise it is a head off job
Staffordshire Area Meeting 28.05.2026
I echo the remarks of Foz
Northwest England meets
As temporary area sec I am interested but am out of country until mid May. I will contact you then Ian
Sierra Ignition Switch Power cuts to Aux 1 on Crank
Dropping power to aux1 dates back to cassette tape deck audio systems. When cranking the volt drop caused the auto-reverse to partially activate and tangle the tape.
Historical vehicle status
The rules are that the vehicle has to be first registered more than 40 years before 1st April ( I had a May first reg so a nearly year long wait) and to not have been substantially modified in the last 30 years. ERA say that the tiger cat was first made 24 years ago so you fail on the second qualification. You car will have inherited the donner first reg but have been converted post 2002. MOT exemption is something I personally do not like. I still MOT my cars as proof that I have maintained them to at least a basic standard. If you have a crash and no MOT (even if exempt) your claim will take a lot longer as insurance companies look for any reason not to pay.
Rear suspension
I fitted Gaz coilovers to the back of my exmo around 20 years ago. They are connected to the rear of the swinging arm and have had no problems in over 50,000 miles. The shock mounting hole needed enlarging to I think 1/2inch to accept a larger rubber bushing.
Wet Weather Kit S&
have you tried http://www.softbitsforsevens.co.uk/
GBS Zero Rescue
White earth and black live is american convention.
GBS Zero Rescue
Filler plug doubles as level setting
GBS Zero Rescue
Use to use loctite all over the place on production machinery but only on shcs bolts which are automatically high strength if obtained from good suppliers. If there were problems undoing a bit of heat denatures the loctite approx 200C.
Starter motor confusion
As far as I recall all pinto engined sierras used the same starter regardless of engine size. There were about 5 interchangeable manufacturers of the starter. I think that some of the pinto cortinas had a bendix starter rather than a pre-engaged starter but I could be wrong. Is the flywheel chamfer towards the starter (benix) or away from the starter pre enguaged.
Another Alternator Question
I follow your logic and think there is a fault in the rectifier whereby one of the 9 rectifier diodes or the clamp (load dump) diode has failed. The diodes will be in the alternator body.
Electric ignition for 2.0l Pinto
The one I was recommending is the earlier generation that does not have any connection to the carb.
