IanS
Area Secretary
  1. The thing to remember is that the vacuum advance is there as an economy measure whilst at low throttle settings. At low throttle the pressure in the cylinder is low before ignition and in the burn time is therefore longer so to get max economy the ignition needs to be advanced.
  2. https://www.s-v-c.co.uk/categories/stafford-vehicle-components-washer-wiper-systems-wiper-systems made to measure system which appears to be in stock. Longboarder on the forum did a how to adept for wiring to this type of system
  3. IanS replied to Andi's topic in Events
    Had an excellent day out until Martins hollow legs betrayed him and I had to find half a cow to feed him. Thanks for organizing.
  4. Be warned that the standard wipec rear light cluster points the bulbs sideways. Replacement LED bulbs then shine sideways, not back☹️
  5. Sorry to hear this. I hope that nobody was hurt. Is it just cracked or more more serious? Car still derivable? Fingers crossed for you
  6. I do not know what ignition switch you have. I had this problem on my sierra derived switch. The contacts inside the switch had corroded. I stripped the switch and polished the contacts reassembled it. The problem went away.
  7. The one I have as spare is marked CCL6268 equivalent to QCC1334 VJC769 it has dimension A 40inch and B 52inch
  8. I have used the clutch cable off a 2WD Cosworth sierra as it is a bit longer than the standard sierra cable and thus is easier to pass round the exhaust. When I get the kit out tomorrow I will look at the part number provided my age brain remembers.
  9. Like Foz I have a pass out and should have similar timetable. Ian
  10. IanS replied to Jon Green's topic in Engine
    The pinto as standard is a non contact engine but with a FR33 cam I do not know. The sound of valves hitting pistons is like a bunch of twigs snapping. As for damage you could just try fitting the new belt and seeing if it starts. if it does I would replace with a new one anyway. Otherwise it is a head off job
  11. I echo the remarks of Foz
  12. As temporary area sec I am interested but am out of country until mid May. I will contact you then Ian
  13. Dropping power to aux1 dates back to cassette tape deck audio systems. When cranking the volt drop caused the auto-reverse to partially activate and tangle the tape.
  14. The rules are that the vehicle has to be first registered more than 40 years before 1st April ( I had a May first reg so a nearly year long wait) and to not have been substantially modified in the last 30 years. ERA say that the tiger cat was first made 24 years ago so you fail on the second qualification. You car will have inherited the donner first reg but have been converted post 2002. MOT exemption is something I personally do not like. I still MOT my cars as proof that I have maintained them to at least a basic standard. If you have a crash and no MOT (even if exempt) your claim will take a lot longer as insurance companies look for any reason not to pay.
  15. IanS replied to John Timmins's topic in Mechanics
    I fitted Gaz coilovers to the back of my exmo around 20 years ago. They are connected to the rear of the swinging arm and have had no problems in over 50,000 miles. The shock mounting hole needed enlarging to I think 1/2inch to accept a larger rubber bushing.
