Daveo
    Robin hood
    David Spence
    Leeds
  • Interests
    Retired mechanic, computing , grand kid's , koi carp pond , motorbikes.
1,677 profile views
Daveo's Achievements
Getting there Builder
Getting there Builder (3/6)
0
  1. Hi , I had a similar problem 3 years ago If you dizzy connects with a plug from the wiring harness on the dizzy check it for corrosion mine did the same thing I replaced the plug in the dizzy and the harness hey presto all good. just something else to check.
  2. Hi The Sierra one is also a pinto every thing should just swop over 99.99% .
  3. Hi you could try reconditioned plates and flywheels i used a place in leeds but i`m sure that theres someone near you that will do the same thing i have included this website so you get an idea CG Motorsport - Performance Clutch Specialists they refurace the flywheel on all flywheels and if its a duel mass again surface and new tension springs they aldo will resuface you original clutch plate so its all like new.
  4. try this guy for a rack as alot of ford spares pedrosky666 on eBay
  5. I would look for some more while welding can be done the rust is eating away under it you could try this bloke i have used him nice willing to help pedrosky666 on eBay
  6. hope this helps.
  7. I had mine rebuilt it looked better than new and is still works great. you can try people like this Starter Motors | Reconditioned Starter Motor | Cheap Prices or search via web browser "starter motor reconditioning"
  8. LOL
  9. 3/16th drill bit 3 seconds later out or as HawkNorth said grinder , less than 3 seconds only made out of ally.
  10. Daveo
    Thermostat
    make one get gasket paper from auto supplies then put part of the paper on the opening for the thermostat trace round , cut out takes about 20 mins money saved when putting it on use a small amount gasket sealer both sides .
  11. Radiator Hose Ford Sierra 2.0 Upper for sale | eBay They have bottom and top there is the flex one by gates.
  12. Daveo
    Fuel Vapour Separator
    try the above
  13. Daveo
    GENUINE BRAND NEW FORD SIERRA PINTO SOHC CARBURETTOR FUEL VAPOUR TRAP | eBay try this...
