September 2, 20241 yr Hello I have a Marcos Martina with a 2 litre pinto. I have rebuilt the 32/36 and am about to put it back. It has two vacuum pipes coming out of the underneath of the carb. I have traced them and they go to the PCV valve. I would like to replace the valve but I cannot find one with two vacuum points like mine. Is this a normal set up, please? What is the best solution? Many thanks John
September 4, 20241 yr Please try and post a larger and higher resolution photo, the one I see is not clear enough to see what you have got.
