Webber carbs
Hi just had Webber carbs 32/36 fitted , I have purchased 2 synchrometers and when I check them can’t get them to balance … I have adjusted idle screw and mixture screw but I think i might be missing something…is there another screw to balance carbs ??? Thanks
Are we talking about DGV32/36 (might be DGAV32/36)?
If so these are primary/secondary carbs where the smaller chock (primary) opens first and then when larger amounts of power are required the larger (secondary) choke opens. These carbs do not need balancing.
Thank you that makes sense just checked DGAV 32/36 thank you for your help
