Steering Lock
Guest Simon M
Guest Daren.F
Last night whilst out for a blast, I took a Left hand turn, Quite fast, And the steering lock engaged half way round the turn.
I managed to free it before the ditch, but I dont know why it happened and i'm not to keen on it happening again.
I intend stripping it tonight and will report back
Has anyone else had this fault?
( 2b, Mountney wheel and boss) :(
Guest Daren.F
Having stripped the steering I found nothing amiss !
I can only assume the pin on the steering lock drops down a fraction under cornering G forces,
I have filed a bit off it, If I turn up at newark you'll know it worked.
Guest stevie b
Darren
I had a similar problem on an Escort; it was a worn ignition switch.
Also I trouble with steering lock not working, It was caused by the steering wheel boss. I filed it and it works well after making sure that relative spacings were correct .
Steve
  • 7 months later...
Guest 2BBoulton
I thought that the plastic lugs on the boss were to cancel the indicater after completing a turn, or at least thats what they did on my Mini (if I remember correctly)
Bruce
Im taking my steering lock off post SVA, i dont fancy this happenning at all!!! :o
I have enough problems correcting sideways action as it is, i dont fancy trying it when the steering wheel doesnt want to play along! :(
Stu :D
Guest michael
this may help the sva requires a anti theft device if the steering lock dont work you will need somthing else i fitted a battery cut off switch so the sva man said thats ok.....reg mike
