The Superspec was notorious for breaking clutch cables. The reason was traced to the fact that where the cable entered the pedal box it changed direction by about 10 degs and then attached to the pedal. This meant that every time the pedal was depressed the cable was put under a sideways tension. Once they are modified to remove that bend and the inner cable stays perfectly straight then the problem goes away.
