1186497
303 -
Posts posted by 1186497
Evening, just after a quick bit of advice before I do it wrong
Have 3 wires from the Bosch alt
B+ - easy enough - straight to battery
D+ - warning light? Do I have to have one?
DF - ?
Thanks for any help
Simon
Thanks for the pic. I haven't got a header tank, or expansion tank which I've seen some people have when googling.
Everything else looks ok, is the header tank essential, I am using a radiator with pressurised cap if that's makes any difference
Evening
Looking for a little advice.
Struggling with the cooling on my zetec as I can't get the water fully circulating round. I am running the water pump the wrong way but I don't believe that is a major issue especially when just idling which is all mine is good for at the moment.
So a couple of questions, 1st pic, am I being too optimistic with the angle of this pipe?
2nd pic, currently I've blanked this off with a screw as it was shooting water everywhere, I'm 99% sure this isn't the answer, what's it supposed to do?
Any help really appriciated
Thanks
Simon
HI David
Just done the test you mentioned and got 5 litres in around 2 minutes 30.
Does this sound ok?
Will go for the full clean option rather than just spraying the bits, have one plastic filter between pump and carbs but both are in the engine bay. Will get a metal one ordered just in case. Why does the pump need to be near the tank? DFitting in the engine bay is 100% easier as geting to the tank would be a right bugger. Currently have it mounted to the back of the passenger footwell firewall..
Thanks
Simon
Thanks for the responses.
Tractor will PM you now with an email address as that would be great to get the map.
It does rev although tries to stall when throttle slightly opened, once engine is warm it seems to be better albeit a bit lumpy.
I think stripping and cleaning the carbs is a good shout so i'll do that this weekend and see how it is following that.
Just a thought i have an R1 bike fuel pump connected diretly to the carbs - assume this does not need a pressure regulator.
Simonn
Evening, All sorted.
After stripping the carbs I couldn't see anything wrong, however I had forgotten to blank off the vacuum input into the inlet manifold, once this was done all was good, albeit still ropey.
Still a couple of issues though,
1. Does anyone have a Megajolt map that I could upload as a start - Standard blacktop on Standard R1 Carbs.
2. Only starts if the choke is opened, after which a blip of the throttle and it wants to die....if you do it slowly of when hot then its ok - could this be flooding,
3. Really cant get the throttle cable to have a smooth action, anyone got any pics of how they have done theirs. I'm using a bike cable as fits the R1 nicely but getting it to the pedal is a nightmare as doesn't return fully all the time. Albeit once I do get this working I have found I cant wear shoes when I want to drive it.....using a zero pedal set (another mistake) and the pedals are very close together - I'm telling myself this is a good security measure.
Cheers for the previous help....got a bit more motivation now its going!
As it looks like I need to take the carbs to bits is there an ideal inlet jet size for a 2l blacktop? Thinking I may as we'll change if need whilst I'm there as think these are straight off the bike.
Anything else I should do whilst I'm there?
Simon
Perfect, thanks, will just fit some flush then
Cheers for the clarity, I'll get them swapped
Hi all
Cheers for the ideas, tried them and to no avail.
Nigel you 100% number 1 is cambelt end? Mine is set up on the coil pack with the shortest lead on coil pack at number one so I had it the other way round. Never checked just assumed who I got the coil pack from had it right. Would it still start if in reverse?
Not got a compression tester so may save that for the last check. Stripping the carbs it is then, sure I'll find a guide online but if anyone has one to hand that would be great
Cheers for the help
Simon
Hi all
Any help would be greatly appreciated on things to check befor I strip the carbs down
Running (or trying to) blacktop zetec, r1 carbs on megajolt. Exhaust is cold on the cylinder 1, closest to the coil pack, if I have that right.
Plug shows no sign of running but does spark when removed and checked.
What would you check next??
Thanks for any help
Simon
Cheers guys, still not 100% decided but think I'm going for some that are multi functional all in one light.
Does anyone know if the lights have to come sit at a certain angle for the mot? I'd prefer to mount straight to the wheel arch with no casing but that would mean they angle up slightly?
Evening all,
On the final leg...I hope of getting my 2b back on the road. Apart from getting the engine running as it
should I need to get some rear lights sorted.
Bought these last week but the housings are really bad quality so are going back
http://www.ebay.co.uk/itm/231058646182?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
So does anyone have any good recommendations for rear lights. Ideally small, LED, multifunction so as to keep it as minimalist as possible
Any ideas really appreciated
Thanks
Simon
Evening all,
I have a zetec blacktop with R1 carbs mounted by way of a ST170 plastic manifold. My issue is the manifold isn't angled enough to make the choke chambers sit straight so I think its going to run badly.
Is there a better solution to this, I imagine a custom manifold is the expensive answer?
Thanks
Simon
Hi All.
Another wiring post, want to get the zetec fired up to give me that motivation to put the time in to finish this summer! I feel i'm nearly there but pretty much a beginner in wiring. I have all the bits...I think, its just a case of trying not to fry everything. Rather than trial and error and risk that I thought it worth putting on here for feedback. Attached is a very rough diagram. No relays just fuses, so please let me know where changes should be made...asd im sure there are lots. Biggest concern is not killing the megajolt and edis4.
Thanks for any advice
Simon
Cheers guys, will have a bash tomorrow night hopefully and start to make some progress...
In fact looking at it, if I have my shielded cable do I connect one end of the shield to the edis4 (via a smaller guage wire) and also to an earth point on the chassis, so in effect have two wires coming off the shield.......and then do again at the other end?
Thanks Paul, Found an image on google which reassures me I am not on completely the wrong track! Although cant upload for some reason.
Bit of advice needed if anyone can help please.... Just wiring everything up to the Edis 4 and Megajolt and have a couple of questions. Firstly am I doing it right, and secondly how the heck do you connect the cable shield?
Im following the below, and so far have the wires coming out of the edis unit with spade connectors on the end, connecting then to the crank sensor etc.. hopefully that sounds ok.....theory was to keep it fully removable.
The VR sensor, PIP and SAW I was planning on using a bit of the shielded wire and solder directly to the pin of the edis 4 (got one without oem connector) then to spade connectors and out to where it needs to go. However wiring the cable shield directly to the edis 4 is near on impossible as it is a big old wire??? can I trim it down or do I need to wire to a smaller gauge wire first??
Thanks for the replies, went to the two at Barnsley which were good, quite a contrast as ones a fun / traditional one.... cars dumped everywhere and piled high. The other one organised but limited. Got all the wiring I need, but no edis 4....they were wise to them making £25 on ebay so took them off on delivery. Ebay it is.
Cheers guys, will check out the ones in Barnsley today if there open
Marsbar- have everything apart from wiring and edis 4, thanks for the offer but hopefully have all the other bits.
Hi all, Need to find a good scrap yard near the leeds/York/Doncaster area, anyone know of any good old fashion ones where you can go and clamber around?? Need some stuff off a zetec and ideally an edis 4 module if im lucky Thanks Simon
Cheers all, didn't realise they had resistors built into the connectors so that scuppers my original plan. Off to a scrap yard tomorrow if I can find one as the good old days of them being everywhere seems to have been killed off by health and safety!
Alternator
in Electrics
Cheers guys that helps. No iva thankfully just an mot to get through!
Simon
