4,797 -
106
Posts posted by tractor
just been out for a blast this afternoon so depends on the weather for next weekend
WOW me Jayne and Daniel are going to make it
one blindingly obvious problem with the title of your post Matt is IT AINT BLOODY FINISHED THOUGH IS IT
if you want to be wafted about in the lap of luxury Neil buy a Bentley
EFI
Electronic Fuel Injection
if its fuel injected then its unleaded
14 degrees at tickover sounds a bit high I am sure used to run mine at 10 degrees but been a while since I worked on a pinto
Some aftermarket zetec sumps have problems with dipstck hitting the baffles or some people call it the windage tray but basically the hole through it is to small and slightly not in the Wright place so on my sump I made the hole bigger so dipstck now passes through it rather than pushed towards the crank
- 2
To narrow down the fault disconnect the return pipe at the common rail then plug the common rail and connect a bottle of deisle to return pipe if it drains away then there is a problem with the return circuit
On the lorries this can happen when the return pipe comes detached in the tank
i will be coming over in my tin top cos got some doors for gaz if he turns up
you can have a lift if you want Keith or any other leicester peeps
will see if i can make it to this one
well done Neil now you have delved into the depths of your engine and fixed the problem its not as difficult as some people think eh
I can make it next week
Ah now you're just being big headed wallerZ
or just let it all hang out Dan
it can be mounted underneath
its a tidy design
Dean didnt mention that he had to weld an adapter plate to the rs manifold to get it to fit the zetec
just ordered my performance boost manifold from them through ebay and just messaged them to make it a top entry for turbo
As it's a Saturday I can make it so put me on the attendees list please
You have the silver top engine which can't rev to high cos of the hydraulic lifters
so going to go back to a full ST170 setup running VVT and turbo set rev limiter to around 8000 maybe a little more and see wot happens
Best Pedal Box To Use
in Mechanics
i used the one from kit spares when i converted my 2b to zetec
