1,714 -
19
Posts posted by jaimo
Just started to change fuseboxes on pws loom as need more the ignition live ha
1.non fused supply from side lights switch through fuse then on too light
2.ignition live supply with then through 2 fuses goes to wiper reverse etc and anorther to brake switch indicator switch etc
But off the ign supply side so non fused power is a black wire has anyone got any idea what this is as doesnt mention it in instructions thanks
They not fixed in yet keith but well spotted
The speedo works from pulse from speedo drive adaptor the xr2 ford pulse unit we fitted it and worked on stus so tried and tested didnt get the cbs ones chris as they sent me black face stopped doing white ones so sent back and got dolphin gauges
Havnt tried any yet due to no wiring in car and got to remove tank to fit new fuel sender should be fun
Dash update still got wiring loom to fit and all senders etc
Before
After
Look what came today
Finished ready for fuses relays etc
Made a box to fit fuseboxes relays and now megajolt thanks for tips on electrics post will have a covered front on when done picture sideways for some reason
Dash now done ready for clocks wife helped finally converting her she now calls it our kit car
Okay covered the tunnel today with vinyl and sat heater in place
Thanks chris i will hopefully beable to sort it from there but then again
Yeah bob i meant that cable but join at starter end thats correct isnt it
Chris any diagrams etc brill
Has any got some diagrams that they made or any instructions or tips etc for premier wiring pinto loom
As got one and trying to alter slightly and cant understand a fews bits such as in rear loom the fuel pump wire where does feed in loom/fuse come from and where best to take power from for drls ignition live and megajolt coil pack etc also ignition
Also changing fuseboxes to bigger ones
Also how and where do i connect output from alternator to starter solinoid to battery
Help
Dont start this again
Looks and sounds sweet chris well jealous think for nxt winter time to think engines i will drop it off for you october time
Premier Wiring Sierra Based Loom
in Electrics
The only black wire on instructions is the headlamp flash goes to pin 15 on dip switch for bg83 stalks (switched live)
